How to control Stepir from remote computer
I run remote a lot...
Here is how to control the SteppIR
1. Start SmartCAT and SSDR on the Local Computer
2. Load DDUTIL onto the Local Computer that controls the SteppIR
3. Stop SSDR on the Local Computer
4. Leave SmartCAT and DDUTIL running on the Local Computer
5. Start SSDR on the Remote Computer
The SteppIR will now follow frequency on the Remote Computer because it is reading frequency from SMARTCAT on the Remote.
Neal Campbell helped me set up this same arrangement and it works perfectly.0
Very cool! Thank you guys. I will try this tonight when I get home from work.
So I don't need to run DDUTIL on the remote computer? I was using it on the remote computer for my logging software (HRD).
I haven't tried DDUTIL on my remote yet... but then while i use HRD Logging, I rarely log contacts unless they are Rare DX...I will try it later today to see if I can run 2 instances of DDUTIL on the same network.
For those of us more paranoid types, I have installed a Moxa N5410 IP to 4 serial port server on the network and it can accept up to 4 simultaneous connections. So I can have DDUtil on the local computer and DDUtil on the remote as well. The Moxa software sets up virtual ports on each computer. As Ron Reagan said, "Trust but verify"
No u don't need ddutil on the remote to control the SteppIR at Local
I had to set up DDUTIL with the proper Serial port and to specify the protocol. Having great success with a USB to serial adapter.0
If you only need HRD Logbook & DM780 on the remote computer then why not run MiniDeluxe 2 on the remote computer and DDUtil on local PC for StepIR and other peripheral integration? Dave, wo2x0
That is exactly what I am doing. Using DDUtil with a local computer with a USB to serial adapter plugging into the SteppIr serial port.
As a test I just ran DDUTIL on both my Local and Remote Computer
2 Instances of DDUTIL operating at the same time (one on Local and one on Remote) definitely works OK
I could run HRD Logbook on my Remote Computer under one instance of DDUTIL
And the LP-100, rotor, SteppIR on my Local Computer
It is just too bad the LP-100, Rotor, SteppIR are tied to the Local serial port rather than being Ethernet devices..
But Heck it will likely take another century to pass before other Ham Manufacturers abandon serial ports and join the 21st century Ethernet...
Howard
Thanks for your help with this. StepIR is working great remotely now.
Icom has joined the Ethernet band wagon. My 7800 remotes stand-alone and it can also control the SteippIR through the antiquated CI-V port. It's almost a SmartSDR in that I have an SDR-IQ piggy-backed to it so I get the same panorama as the SmartSDR. However, I prefer the Flex because of its wonderful potential.
Jim
My N4PY Pegasus Plus can run using it's client-server and provide full control for LP-100, rotor, steppir, and various antenna switch boxes. Also, Pegasus Plus can give full remote CW paddle operation using a K1EL winkey keyer.0
Carl
Thanks for that info.. I plan to download and test it out on remote
Now if you could only figure out how to put spots into the Spectrum Display (like in NaP3) I would be first in line to buy your product.
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 372 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
