How can I get a 10 MHz reference output?
I started using MSK144 recently on six and many of the stations I contact claim my frequency is about 80Hz low. MSK 144 is frequency sensitive as FT8 and CW are not so I only became aware of the situation when I started using MSK144. I wanted to verify that my 10MHz reference either locked to GNSS or the TCXO is right on frequency. I cannot figure out how to get a 10MHz output or is it so low my counter can't see it? I can't find a spec on what level the 10 MHz reference output should be and/or what the impedance of the reference output is. Or have I not turned it on?
The 8000 series radios with GNSS do not have 10 MHz output.
Look at Settings/Radio Setup/GPS. Verify how many satellites you have visible and how many are tracked.
Currently I have 32 visible and 17 tracked on my 8600. Frequency error is -181.7 ppb
Make sure under Settings/Radio Setup/RX that Reference Source is set to Auto and should show GNSS Lock if you have enough satellites tracked. If you have 5 or fewer satellites tracked, you might want to relocate the GNSS antenna. I bought an SMA male to female 15 foot cable and located my GNSS antenna outside.
73 Dave wo2x
I usually have 12 or more satellites visible and frequency error of 100ppb or so. Reference source is set to auto.
The radio is locked to GNSS but I want to measure the 10MHz reference on the back panel but there is no signal there.
That's for a 10Mhz reference input if no GPS attached.
The 8600 had a 10Mhz output. See image below. You can clearly see it.
Unfortunately It did not work. See the Oscilloscope output. I was told it was a software bug.
Then the radio bricked twice in 2 days. 1st time I could recover it using a image from Flex. Next day it bricked again and I had enough and sent it back.
Mick…That's interesting. I have an 8600 and there is a hole plug where the 10MHZ Out connector is in your photo.
Do you have the GNSS installed or the optional GPSDO? The stock GNSS does not offer a 10MHz output but the GPSDO does.
I had the GPS installed
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI wonder if the 2 cables are misconnected. Try testing the 10Mhz in Port and see if there is a signal on it.
Mike, I sent the radio back. It was the 2nd radio that had problems and I decided to keep my 6600.
thx.
- 685 The Flea Market
- 102 Aurora
- 994 Maestro
- 970 Genius Products
- 357 Tuner Genius XL
