Made A Mistake
Just upgraded to 4.2.18 and had a brain cramp and reimported my saved profiles from 4.0.1 Is this a problem? ^400M is my radio. Thanks in advance
Bob,
Importing profiles from a previous version should never be a problem. The imported profiles are merged with any existing profile that you may have had in the radio. If you wish to have the 4.0.1 profiles only, do a 'factory reset' ( which wipes all radio profiles except radio defaults ) and import your 4.0.1 profiles.
AL, K0VM
except in this one instance, v4.0.1 did not convert profiles properly when upgrading from v3.
importing profiles saved from v4.0.1 can lead to problems.
if your radio gets “wonky” after importing profiles that were saved from v4.0.1 after upgrading to v4.2.18, REPEAT the Factory Reset and DO NOT import the profiles.0 -
Ken, when did v4.0.1 come out that may be effected? I have had some crazy weird issues and may be Profile related but I hate to have to rebuild all of them as I have probably over a hundred profiles.
Having the release date will give me a approx. time frame to load that may be safe to use on 4.2.18
Never mind Ken it looks like I downloaded it on 11-8-25 and installed my Profiles for version 3.10.15 were last saved 10-30-25, (says right in the Profile Naming)
- 394 Community Topics
- 670 The Flea Market
- 174 SmartSDR+
- 452 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 76 Aurora
- 319 FLEX-8000 Signature Series
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 834 Peripherals & Station Integration
- 146 Amateur Radio Interests
