Made A Mistake
Bob
Bob Member ✭✭
Just upgraded to 4.2.18 and had a brain cramp and reimported my saved profiles from 4.0.1 Is this a problem? ^400M is my radio. Thanks in advance
  • Al K0VM
    Al K0VM Member ✭✭✭
    Bob,
    Importing profiles from a previous version should never be a problem. The imported profiles are merged with any existing profile that you may have had in the radio. If you wish to have the 4.0.1 profiles only, do a 'factory reset' ( which wipes all radio profiles except radio defaults ) and import your 4.0.1 profiles.
    AL, K0VM
  • Ken Wells
    Ken Wells Community Manager admin
    except in this one instance, v4.0.1 did not convert profiles properly when upgrading from v3.
    importing profiles saved from v4.0.1 can lead to problems.
    if your radio gets “wonky” after importing profiles that were saved from v4.0.1 after upgrading to v4.2.18, REPEAT the Factory Reset and DO NOT import the profiles.
  • WX7Y
    WX7Y Member ✭✭✭✭
    Ken, when did v4.0.1 come out that may be effected? I have had some crazy weird issues and may be Profile related but I hate to have to rebuild all of them as I have probably over a hundred profiles.
    Having the release date will give me a approx. time frame to load that may be safe to use on 4.2.18
  • WX7Y
    WX7Y Member ✭✭✭✭
    Never mind Ken it looks like I downloaded it on 11-8-25 and installed my Profiles for version 3.10.15 were last saved 10-30-25, (says right in the Profile Naming)
