Option to Automate the AGC-T setting
13»
  • Alan
    Alan Member ✭✭✭✭
    Bill and All
    Looking at the Flex codec outputs available from the VITA49 meter packets, there are three:
    • 24kHz broadband slice receiver signal level
    • The signal strength of signals in the filter passband
    • Signal strength after AGC
    My ears cannot hear audio from the Flex Audio Out when the signal strength is below -40 dB. My hearing audio out level holds with either noise at -40 dB or with signal/noise at -40 dB.
    So, using the "Signal strength after AGC" codec, my app automatically adjusts AGC for -36 dB (3 dB above my hearing threshold) while tuned to noise only. This is working very well.
    Any thoughts on using "math" and the three available Flex Codec levels to calculate the noise floor from the combined noise/signal?
    Alan. WA9WUD
    Hi Alan, when you say "my app automatically adjusts AGC for -36 dB ..." do you really mean the AGC-T?
  • Alan
    Alan Member ✭✭✭✭
    Len
    Well, you have me scratching my head. I used this guide for my auto AGC app : https://www.flexradio.com/videos/flex-6000-receiver-tuning-how-the-agc-t-works/
    API commands include:
    • Mode Command, "slice set <slice number> agc_mode=<mode>". (off, slow, med, high)
    • AGC Threshold set, "slice set <slice number> agc_threashold=<value>" ( 0-100)
    • AGC Off Level set, "slice set <slice number> agc_off_level=<value>" (0-100)
    Are we talking the same?
    Alan. WA9WUD
  • WX7Y
    WX7Y Member ✭✭✭✭
    Alan could you send a link to your AGC-T Flow I would like to check it out?
    tnx
  • Alan
    Alan Member ✭✭✭✭
    Here is a link to a YouTube Video of my Auto AGC in action.
    You can see the changing AGC Threshold when the signal strength changes, and when I manually change the AGC threshold and you can see the auto-driving back to the set point.
    It seems to work well adapting to the signal level and the noise levels.
    Comments?
    https://www.youtube.com/watch?v=hMelo3X3tdk
    Alan. WA9WUD
  • Alan
    Alan Member ✭✭✭✭
    I added a button to turn Auto AGC on/off.
    Here is another video showing the Auto AGC on/off button and how it responds to only noise.
    Alan
    https://www.youtube.com/watch?v=bvJqD7_AZAE
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    The auto profile save would be ok if it were user choice on or off. The auto agc might be tolerable if it were user set to on or off.
    I agree with Sergei. The current agc doesn’t work very well. The threshold for noise level is useful if carefully adjusted, but does not function properly on strong signals if adjusted for weak signals, so constant fiddling with the volume level.
  • Alan
    Alan Member ✭✭✭✭
    I continue to work on an "Auto AGC" Node-Red-based application. I am getting excellent results with virtually no background noise in any signal/noise combinations.
    I am using the Flex API Codec, Signal Strength After AGC", as the controlling input to adjust the AGC threshold.
    It works very well "dynamically," adjusting AGC Threshold to all signal/noise combinations.
    I added AGC basic controls.
    I added Auto AGC controls.
    The Slow/Medium/Fast adjusts how quickly each iteration occurs to change the AGC threshold to make "Signal Strength After AGC" match the selected set point.
    Please feel free to comment.
    Alan. WA9WUD
  • Trucker
    Trucker Member ✭✭✭✭
    Nice work!
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    Hi Alan,
    Do you have any video on CW signals? It would interesting to see some video comparing it’s effects on strong, medium and weak CW signals as you move around the band.
    I’m a CW only OP but your SSB videos look good. It would be interesting to hear some more feedback from other SSB operators and some other Node Red users.
    I would still like to see this integrated in SSDR along with the AGC-T line on the panadapter. Maybe Flex has an opening in their programming team…
    73, Al / NN4ZZ
  • Alan
    Alan Member ✭✭✭✭
    Al
    CW video with CW using my latest version uploaded to YouTube.
    Alan. WA9WUD
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    Alan,
    That CW video sounds good. It's hard to compare the performance of your automation to the existing manual settings that the SSDR software offers without having access to both. But it does sound good.
    I wonder if the FRS technical team has seen your video and your approach. They don't comment here as much as the used to so not sure how much they monitor these posts. But It would be interesting to hear from Steve, Eric or Tim and get their thoughts.
    Regards, Al / NN4ZZ
    al (at) nn4zz (dot) com
    6600 Win10 Pro V2004 -- SSDR V3.3.33
  • Juan TG9AJR
    Juan TG9AJR Member ✭✭
    Great and I love the idea, count my vote in.
    Juan / TG9AJR
  • K6HN
    K6HN Member ✭✭
    edited December 2022
    Nice work Alan!
    Hopefully you will share the code soon as it looks great and your video's show a promising result.
  • Alan
    Alan Member ✭✭✭✭
    I added another Auto AGC video.
    https://www.youtube.com/watch?v=vQ5BYy0nlM8
    I made some improvements to the auto functions.
    SSB Phone Net, with low-level signals, S4 to S8.
    Note how the Auto AGC adjusts to the different signal levels, keeping the noise low.
    I demonstrate the algorithm by manually moving the AGC threshold up, and you can see how the app re-adjusts to match the "After AGC Level" Codec to set point by changing the AGC Threshold Level.
    We are testing more and will publish the Node-Red flow in a few days.
    Alan. WA9WUD
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    Just saw this note from 2026 Flex banquet in Dayton.
    Russ Ravella Member ✭✭✭5:08PM May 16, 2026
    I just read a post on the Flex groups.io forum saying:
    "It was announced at the banquet of
    SmartSDR Upcoming Features
    ………………includiong
    Automatic AGC-T Threshold"
    This idea has been at the top of the list for years….requested in 2014 and 142 votes.
    Glad to see it coming….and hopefully it will have many of the the features, options and the display discussed in this post.
    Regards, Al / NN4ZZ
    6600 SSDR V3.9.18
    TGXL 1.2.17
    PGXL 3.8.9
    Win11
  • Russ Ravella
    Just a comment on this … if I remember correctly Hayley Boynton, Flex's Director of Software, explicitly mentioned this during an interview at the time V4 was released as something being worked on already at that time. So it makes sense that it's actually going to be released soon as that was several months ago now.
    73 Russ KR6W
  • Dave_WB1S
    Dave_WB1S Member ✭✭
    I am in favor of adding auto AGC-T. I will have to use it for a while to determine if I like it and find myself using it. Retaining manual AGC-T is an absolute must for weak signal CW as Bill-K7UOP mentioned. For weak signal I vary: bandwidth, AGC-T, APF, DSP filters frequently to improve copy. I have found manual control can make the difference between copy or no copy for weak CW. I also recommend retaining slider control for APF and DSP
    Dave - WB1S
  • Duane  N9DG
    Duane N9DG Member ✭✭
    I think the trick will be to implement it with a more or less set and forget initial manual setting to allow the operator to specify just how much natural background band noise that they like to hear. And then from there the auto AGC-T maintains that level (or ratio to desired signals) across different bands and changing band conditions.
    People have very different opinions on how much band "hiss" between syllables and CW elements they like to be able to hear. So I don't believe that it can, or should be hard coded. The key thing a well done auto AGC-T will help to do is help to minimize people's tendency to have the AGC-T cranked in too high. Every time I hear someone complain that a Flex is "noisy", I KNOW that they have the AGC-T set incorrectly and/or have too much front end gain enabled.
