TeensyMaestro
1192021222325»
  • Kuno
    Kuno Member ✭✭
    Len,
    I forgot to mention that I tested V2.004 and v2.005 beta this afternoon. Unfortunately, both version do not display the initial slice A and B settings. So I went back to V2.003. It does not work either, but at least it displays both slices. I will see what the outcome is with my friends Flex 6600.
    vy 73 de DF1SD, Kuno
  • Kuno
    Kuno Member ✭✭
    Len,
    yesterday I had a chance to test the TeensyMaestro with my friends 6600. Believe it or not it did have exactly the same problems. This leads me to think that the problem must be the Teensy, but what could be wrong? Any idea before I put it into the trash can?
  • G7UFO
    G7UFO Member ✭✭
    Kuno,
    If you’d like to send your TeensyMaestro to me I can give it a fresh look. I can’t promise anything but you never know.
    73, Neil.
  • Kuno
    Kuno Member ✭✭
    Neil,
    thanks for your offer. I have to check how I can prevent customs duties while sending the stuff back and forth.
  • G7UFO
    G7UFO Member ✭✭
    If you mark the category as 'returned items' that will avoid additional duties (as they've already been paid).
