TeensyMaestro
Len,
I forgot to mention that I tested V2.004 and v2.005 beta this afternoon. Unfortunately, both version do not display the initial slice A and B settings. So I went back to V2.003. It does not work either, but at least it displays both slices. I will see what the outcome is with my friends Flex 6600.
vy 73 de DF1SD, Kuno
Len,
yesterday I had a chance to test the TeensyMaestro with my friends 6600. Believe it or not it did have exactly the same problems. This leads me to think that the problem must be the Teensy, but what could be wrong? Any idea before I put it into the trash can?
Kuno,
If you’d like to send your TeensyMaestro to me I can give it a fresh look. I can’t promise anything but you never know.
73, Neil.
Neil,
thanks for your offer. I have to check how I can prevent customs duties while sending the stuff back and forth.
If you mark the category as 'returned items' that will avoid additional duties (as they've already been paid).
Here is a beta version of the TeensyMaestro (V 2.006 Beta 1). Thanks to Graham, G4FNL for noticing that when two slices are tuned at the same time, the acceleration goes wild. This version fixes that issue. I needed an acceleration timer for each encoder, not one for both.
2.006 Fixed runaway VFO acceleration when two VFOs are tuned simultaneously. Changed MTP library to compile under TeensyDuino 1.62.0. No longer need to disable MTP in debug mode. Added PWM sinewave sidetone and AdaFruit TPA2016 class D audio amp.
Note that the sinewave functionality is not there yet. Experiments with it are very promising, so it shouldn't be too long for that functionality.
Give this a try and let me know how it goes.
- 691 The Flea Market
- 197 SmartSDR+
- 462 SmartSDR for Mac
- 113 Aurora
- 978 Genius Products
- 136 Antenna Genius
- 323 Shack Infrastructure
- 228 Networking
