Does Slice Master work with SmartSDR 4.2.18?
Bob Segrest
Member ✭
After removing all earlier versions of SmartSDR (including drivers) and installing v4.2.18, Slice Master 11.g isn't working correctly. WSJT works fine if I launch is directly, but hangs when I try to launch it through Slice Master, Slice Master just hangs...
Any ideas?
Any ideas?
I completely purged Slice Master from my system, including Firewall rules, app settings folder and a pass through the registry editor. Then I downloaded a fresh copy of the Slice Master distribution zip file and unzipped it into a new folder.
Slice Master is starting without any apparent errors, but when it tries to launch WSJT warnings appear in the SM status bar.
WARNING: DAXIQ channel is not enabled in DAX Control Panel. daxiq=1 slice='A'
This is really odd... When I launch WSJT directly, it connects to DAXIQ-A and the SmartSDR DAX IQ stream shifts from blue to green and indicates Streaming.
What am I missing?0 -
Since the names of the Audio End points changed, SliceMaster can't find them and believes that DAX has not started. You'll have to reach out to the author to make changes.
Thank you Mike,
I noticed the difference, but had not found anyone to confirm... Will follow up accordingly.0
- 393 Community Topics
- 669 The Flea Market
- 174 SmartSDR+
- 451 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 73 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 834 Peripherals & Station Integration
- 146 Amateur Radio Interests
