WaveForm Manager
For some reason I can't find the correct area to download the Waveform Installer. Can someone give me a hint/link?
73 Paul w2eck
Paul,
"To get started, download the Docker container from https://github.com/drowe67/freedv-gui/releases/download/v2.3.0/freedv-waveform-2.3.0.tar.gz and follow the instructions over . (In short, go to Tools->Waveforms in SmartSDR, make sure Docker is selected and install the downloaded file from the first link; after a bit you'll be able to select FDVU or FDVL modes on your active transmit slice and begin operating.) The FreeDV FlexRadio integration also includes support for FreeDV Reporter (https://qso.freeedv.org/), which means you'll be able to spot FreeDV signals that you receive over the air and get a live view of what's currently happening in FreeDV."Just download the freedv-waveform-2.3.0.tar.gz link above and install it from the SSDR Files>Waveforms window with the Docker option.
AL, K0VM
Al - thanks for help- got it installed - a couple of other DV related questions
- If you are using SSDR DV - do you show up on FreeDV Reporter?
- What triggers that?
- Change subject - using FreeDV 2.1.0 which I had working but now it is not
- When i go to Tools> Easy Setup > Radio device - the only option showing is (multiple) ; there is nothing else available in the drop down- No DAX choices.
- I am running 4.2.18 on an 8600, radio is in DIGU, DAX 1 is on, and in the Radio panel - DAX is on.
Any idea why DAX1 is not available?
73 Paul w2eck
Paul,
I am not the expert on the FDV …
But I can tell you that with 2.3.0, DAX is not used and specificaly that TX DAX needs to be off. You should select either the FDVU or FDVL mode, not DIGU/L. At least that's the way that i am running it.
AL, K0VM
The DAX device names changed for the Windows version of SmartSDR. If you install the Windows version of 2.3.0 it should recognize the new names (though you may need to reselect the DAX device in the audio settings).
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
