New to Maestro C ... 4.2.18?
I am new to Maestro C. Is here anything special I need to do apart from updating the local connected computer (for data), the remote computer (for updates), and the remote radio?
Is here anything I need to do on the Maestro for this major update?
I understand that you do not need to do anything with your Maestro. That work will be done by Flex in due time.0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYes, when you start the Maestro, you will need to update it to 4.2.18 to match the radio.
Update - Maestro C is working fine with my remote Flex-6400. Both are on 4.2.18 and I really like the Maestro.
Now I am trying to figure out how to configure FreeDV 2.3 to work with the Maestro C and on the connected computer, DAX and CAT. CAT is fine but DAX doesn't work in RX. I assume it has to do with the DAX channel. All FreeDV docs say to use DAX 1 but the Maestro says that it's using DAX 1. I assume that I need to change the DAX channel for FreeDV.
I'll do some research and post the question in the "software" section
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
