Do notch filters work correctly?
Rod w7zrc
I have hardly ever tried to use the various notch filters in SSDR (I am on 4.2.18 with a 6600M). This morning I tried the TNF and it did not seem to do anything. I did a rt click on the passband and selected "Create TNF" then adjusted it for width and placement.
Since I am not used to this feature, I may not be doing it correctly. Suggestions please.
Thanks, Rod w7zrc
Rod…I believe you have to enable the filter with the icon in the bottom left corner of SSDR.
Works on my 6500/MaestroC (4.2.18).. Difficult to setup with the Maestro/xxxxM screen,, It will be yellow if enabled.
AL, K0VM
Or green if it is a permanent filter.
Geoff thanks for the tip - that solved it for me. Don't know why that designed that way but now have the TNF working! 73, Rod
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 980 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 832 Peripherals & Station Integration
- 145 Amateur Radio Interests
