Do notch filters work correctly?
I have hardly ever tried to use the various notch filters in SSDR (I am on 4.2.18 with a 6600M). This morning I tried the TNF and it did not seem to do anything. I did a rt click on the passband and selected "Create TNF" then adjusted it for width and placement.
Since I am not used to this feature, I may not be doing it correctly. Suggestions please.
Thanks, Rod w7zrc
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Answer ✓
    Rod…I believe you have to enable the filter with the icon in the bottom left corner of SSDR.
  • Al K0VM
    Al K0VM Member ✭✭✭
    Works on my 6500/MaestroC (4.2.18).. Difficult to setup with the Maestro/xxxxM screen,, It will be yellow if enabled.
    AL, K0VM
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Or green if it is a permanent filter.
  • Rod w7zrc
    Rod w7zrc Member ✭✭
    Geoff thanks for the tip - that solved it for me. Don't know why that designed that way but now have the TNF working! 73, Rod
