PC Audio not working in 4.2.18
Removed all previous versions of smart SDR, DAX, and VSPs. Installed 4.2.18 with no problem. However, I notice that PC Audio is not working. I restart smart SDR and PC Audio works for about 15 secs and then stops working. All other apps on the computer seem to be ok. Just wondering if anyone else has experienced and can help me to identify problem. Thanks
Hi Fred, it is working for me on my Win 10 laptop. Are you sure that you don't have the master volume (SmartSDR main window, top left) muted or turned down?
Len, it works for about 15 to 20 secs before stopping. Nothing muted that I can see
Hi Fred, you might want to submit a help desk ticket.
PC Audio is separate from DAX. Make sure you windows default sound devices are correct. If you still have an issue, please open a support ticket.
Just installed 4.2 on an older (slow) PC and ran it both locally and remotely.
Audio ran normally BUT:
Around every 2 min there was a 5 second span with no audio then all audio stopped only "fixed" by restarting SmartSDR. No transmit made during this time.
have you shut down the radio and removed DC power after upgrade as per the release notes?
Next step is you should have backed up profiles. Do a factory reset and test PC audio before loading profiles. If working, load your profiles and test again.0 -
What is the configuration of the PC? is it running other software? What does the network condition indicate (green bars)? This may be a PC overload.
My PC has two different audio devices, and always seems to choose the wrong one.
The first / preferred / needed is the on-the-motherboard (Realtek Audio), which actually goes through a mixer to my shack-speakers.
The second / undesired / always-chosen is my monitor, which has built-in speakers (disabled). When Win 11 chooses this device, I hear nothing, yet SmartSDR shows "PC Audio" is blue-selected. Suddenly, I remember, change the Win 11 audio-device, and SmartSDR works again.
So - you may find that Windows is subverting your PC Audio. Perhaps give that a look…
It looks like DAX is working. Do you have the correct DAX input/output selected in the program that uses DAX audio? The DAX audio streams changed names, so you need to reset them to the new values. For example, here is the audio setting for VARAHF:
In Windows Settings, you should see these input devices:
Notice that all the "Reserved" device names no longer appear. It is much easier now to find the device that you need.
Len,
Thank you. I am trying to set up the SliceMaster with the new 8600 and WSJT-X. SliceMaster puts out the message that "Audio Channel is not enabled in DAX control panel, DAX=1, Slice A."
WSJT works when I launch is separately rather than from the SliceMaster. I kind of assumed that if I do not see the Audio line moving in the RX streams of the SmartSDR DAX, then this is where the issue is. But interestingly, when WSJT is working and decoding, there is still no indications of the DAX audio in the SmartSDR DAC panel. How should it work? Should I see the audio lines moving there? If not, what is it for?
Alex
It looks like this is the SliceMaster issue that is not aware of the new DAX drivers.
Alex
Hi Alex, I don't think that SliceMaster works with 4.2.
- 396 Community Topics
- 677 The Flea Market
- 189 SmartSDR+
- 454 SmartSDR for Mac
- 216 DAX
- 390 SmartSDR API
- 87 Aurora
- 328 FLEX-8000 Signature Series
- 986 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 314 Shack Infrastructure
- 219 Networking
- 477 Remote Operation (SmartLink)
- 840 Peripherals & Station Integration
- 146 Amateur Radio Interests
