Adaptive Pre-Distortion using V4.2.18
KD0RC
I got my CleanRF.com -60 dB RF sampler yesterday (ordered Thursday evening).
I have it connected to my KPA 500 with the RF tap going to RXA. I set it up as follows:
I tested it in Full Duplex (FDX) by opening a second panadapter, putting the second slice RX on my dummy load, while transmitting into my antenna. With APD off, I could see a few artifacts from the amp. With APD engaged, it was very clean. This is just a visual qualitative assessment, not a quantitative one, but it clearly shows signal purity improvement.
  • John K3MA
    John K3MA Member ✭✭✭
    You can run a two tone test signal with it off and one and you can count the db improvement of the 3rd order and greater harmonics. Then you can quantify the improvement.
  • ScottGibson
    ScottGibson Member
    I wonder if this would work for SmartSDR for Mac and a KPA500/KAT500 combo. I don't see an APD tab.
