DigU Slice Unmuting by itself
Background:
Aurora AU520M, SSDR for Windows v4.1.5. Headphones attached to windows PC and using PC Audio. N1MM, FRStacks, and SDC CW skimmer.
Issue:
I have two pan adapters in windows SSDR. in Panadapter 1, I have Slice A and when using diversity with my magloop. On Panadapter 2, I have Slice B which is used exclusively with WSJTX and is set to DIGU. I never want to listen to Slice B in my headphones. If Slice B is set to say, 18.100 and I mute it, when I change bands on SliceA , Slice B will usually unmute upon changing bands in Slice A. I'll then hear FT8 in my headphones along with the SSB from SliceA. I can understand muting not surviving restarting SSDR or rebooting the radio, but I'm doing none of those things.
Am I doing something wrong?
Thanks!
Are you using OTRSP in N1MM? If so, does the problem happen without N1MM connected?
- 391 Community Topics
- 665 The Flea Market
- 161 SmartSDR+
- 444 SmartSDR for Mac
- 207 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 824 Peripherals & Station Integration
- 145 Amateur Radio Interests
