DigU Slice Unmuting by itself
Background:
Aurora AU520M, SSDR for Windows v4.1.5. Headphones attached to windows PC and using PC Audio. N1MM, FRStacks, and SDC CW skimmer.
Issue:
I have two pan adapters in windows SSDR. in Panadapter 1, I have Slice A and when using diversity with my magloop. On Panadapter 2, I have Slice B which is used exclusively with WSJTX and is set to DIGU. I never want to listen to Slice B in my headphones. If Slice B is set to say, 18.100 and I mute it, when I change bands on SliceA , Slice B will usually unmute upon changing bands in Slice A. I'll then hear FT8 in my headphones along with the SSB from SliceA. I can understand muting not surviving restarting SSDR or rebooting the radio, but I'm doing none of those things.
Am I doing something wrong?
Thanks!
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsAre you using OTRSP in N1MM? If so, does the problem happen without N1MM connected?
Hi Mike.
The problem persists with without N1MM in the picture.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsWhat we need to do is to make sure this does or does not happen without any other applications connected to the radio. You can't really take WSJT out of the picture, but you might want to turn off the automatic mode setting and see if it still happens.
And, I would also reset the radio and see if it still happens.
- 688 The Flea Market
- 105 Aurora
