Q5 transverter interaction
Hi all,
Just received the 2m 75w version and 50w uhf from Corey. Plugged everything and using an amplifier antenna 9 El vhf and 16 El uhf interlaced antenna. Corey recommended 50mhz IF for vhf and 28 for uhf in order to have less interaction. With 2 slices opened one on vhf and one in uhf xvta and xvtb (flex 8600) when I transmit with 20 watts in vhf I hear myself on harmonics in uhf. Anyone is facing same issue. What can I do? Does it require band pass filters? Cause I never saw anyone discussing about this.
Have you tried a low pass (or band pass) filter after the 2m Transverter and a high pass filter on the 70cm transverter? Those may help. Could also be the 'rusty bolt' issue that often plagues a lot of repeater owners. Full duplex can be a pain at times.
You can get some mutual interaction between VHF and UHF due to the harmonics. You might want to try using a bit less than full power on VHF and that will reduce the interaction.
On my satellite station, the feedline for VHF and UHF run parallel for 60' and just due to mutual induction, I can get some cross band interference.
Adding some sort of low pass filter on the VHF feedline (like 1/2 of a diplexor) may resolve your issue.
Hi both,
Ok I did not expect to see that, will look into some band pass filters.
- 393 Community Topics
- 669 The Flea Market
- 174 SmartSDR+
- 451 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 73 Aurora
- 318 FLEX-8000 Signature Series
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 834 Peripherals & Station Integration
- 146 Amateur Radio Interests
