S.A.T Self-contained Antenna Tracker
Those of you using a 6600 with vhf and uhf transverters - has anyone used the S.A.T Satellite Antenna Tracker from CSN Technologies —
It's designed to control ICOM rigs, but it will work with a Yeasu AZ/EL rotator to track the birds. I don't think it needs to be connected to the radio to work. From what I see, it merely controls the frequency setting on the radio.
If it works as advertised, it would reduce the amount of rotator tuning needed to keep a bird in range.
The CSN S.A.T device will not interface with a Flex Radio.
I provided CSN with a easy to implement method to interface with Flex and they have so far not added same to their firmware.
Alan. WA9WUD
I recently asked CSN Technologies about SAT support they said their latest firmware is supposed to work with Flex radios via TCP/IP wanted to see if anyone has any recent experience with the device?
In our last update, we have added Support for flex radios I’m not familiar with the radios that you’ve listed so I’m not sure which Radio versions it actually works with.If it is a current flex, Radio, the SAT will control it over the network.MikeSent from my iPhone
On Apr 18, 2026, at 5:30 PM, info <info@igatemini.com> wrote:From n3ick@cox.net Callsign: n3ickAre there any plans to add CAT control via TCP/IP for the Flex Radio 6xxx 8xxx and AU-520 transceivers?Thanks
The S.A.T works with the Flex over TCP. The device creates two new pan adapters and two new slices, which can be disruptive to a four slice configuration.
Alan. WA9WUD
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 62 Aurora
- 975 Maestro
- 950 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 819 Peripherals & Station Integration
- 145 Amateur Radio Interests
