PGXL output power jumping up and down
My quite brand new PGXL have been heavily used for about one month now, no issues.
Then one morning I started to operate FT8, I notice that the power is jumping up and down.
lets say I am running 900 watts out, suddenly it can reduse output to appx 500 or 700 or, on rare occations, 0 w.
Now warning, no significant change in SWR.
Setup is Flex 6400M, PGXL, OM 10-1 antenna switch and a 4/5 el quad.
No changes was made since new.
FW 3.7.32
Running SDR 3.5.8
Tom, LA9GX
What version of SmartSDR are you running Tom?
I am using SDR 3.5.80
I am just speculating Tom and throwing out different ideas…
- Maybe power input quality / regulation into the PGXL is fluctuating?
- Maybe one or more of the coax connections is loose? Can you measure the cable conductor (both to the antenna and also the short cable from the Flex to the PGXL) with a meter to check its length for any breaks?
- Maybe a ground connector from the PGXL is missing or loose?
Good luck! I’m sure you will resolve it.
It is also a good idea to test this into a dummy load.
If you don't own a 1500 dummy load, they aren't very expensive and DX Engineering have them at reasonable prices.
3.5.80
Tom, I saw similar power fluctuations when I transmit close to TX passband limits below 300Hz or above 2600Hz. Probably you were working F/H and you answer to Fox station below 300Hz.
73 Boyan LZ2BE
Boyan, Good point! I have observed the same effect. To resolve this, I widened my bandwidth to 100 Hz Low, to 3200 Hz High on my Flex 6600. That eliminated the power fluctuations.
73, Bill NE1B
-1 -
The amp is on it's way to Wimo for service.....
I had the same problem, so has several others, which boiled down too a variety of issues, from faulty transistors, poor soldering and failed power supplies. Absolutely unacceptable to have so many failures from something that costs this much.
I switched over to Acom, currently awaiting arrival for my PGXL, which currently is in Texas being repaired for exactly the same fluctuation problems with output power.
I had the same finger pointing at me, such as "it's your set-up", "It's RF getting into something", "We need to see your operating set up", blah blah blah
Heaven forbid it would actually be an equipment failure, no , that never happens!
After more then 40 years of using amplifiers, building a couple high power tube amps, etc... I was some what put off by the negative attitude towards my "lack of understanding" and that it must be my fault/installation/operating procedures.
I have been using the Acom, my home brew pair of 3cx1500's, PWM AM transmitters, etc... without issue.
The PGXL's are far from bullet proof.
Good luck and I hope they repair it quickly for you.0 -
Hi
Yes, I must say I was a bit put off by the early failure, also having been warned by others.
But the operating easy is very attractive ;-)
So, no bad attitude when I approached them, just a message to ship it back.
A costly thing here in Europe, about 200 USD on my part.
I do belive they cover the return postage.
Anyway, just bought an Amp Supply LK-800 as a backup ;-)
So, lets see how they handle this warranty issue.
73 de Tom, LA9GX
Hi Tom,
Very good! Congrats on the back up Amp, I hope it serves you well. I did somewhat the same thing, I bought an Acom 1200S as a back up. Problem is I like it so much I think I will sell the other when it's fixed, Lol!
I will be looking forward to your post on what they find as the issue/issues. I plan on posting as well once I hear something. This will be the 5th week since they have had it, with no reply yet on when it will hit the bench to be looked at.
Yes they cover the return postage, that's what I was told by Flex.
Good luck and I hope things work out that this will be the last trip for your Amplifier.
73 de Kevin, W9FMC
Hello Tom,
I have the same problem with my PGXL. Dummyload and so on all tested....it is the AMP. TRX output is super stable on TGXL and an analog meter when AMP is standby. What did they do at Wimo with your AMP / what was the problem? It it finally solved or did it happen again?
73 Danny DL7SFT0 -
Danny, I had same issue with my PGXL. Of course, you should note that my problems might not be your problems. I sent it to WiMo for warranty repair.
They confirmed unstable output on all bands and other issues that I was not aware of. Work they did included: corrected Bias current which was 1.6 amps instead of 2 amps; corrected defective soldering on the LDMOSs, corrected cold solder joints in 160m band filter unit; sought advice from 4O3A to check that the amp was now in specification and made calibration adjustment.
It was returned to me in May 2025 since when it has been extensively used and been without issues.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 62 Aurora
- 976 Maestro
- 950 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 819 Peripherals & Station Integration
- 145 Amateur Radio Interests
