Problems with AG firmware 4.1.8
I upgraded the AG firmware to 4.1.8 and immediately had problems. I renamed Antenna 1 and 2 to my dipoles, and both buttons disappeared so I reinstalled the firmware. Now I get a blank box labeled 403A Signature Antenna Gemius Utility with 2 tabs named "local devices" and "Remote Devices," both of which are blank. I have repeated the process of downloading the new firmware and loading it, and I get the same results. One time it worked, and I renamed the antennas, but the same thing happened, and I am back to the blank box. I read others' comments about similar problems, but nothing I do seems to permanently fix it. Any ideas are appreciated. Ed K5YZW
Hi Ed, I am on 4.1.16 (the latest as of 4/16/26) and am having no problems with my Antenna Genius. I can name and re-name the antennas without issue. You might want to consider upgrading to 4.1.16.
Thanks Len. I will definitely give that a try, but I cannot find that version on FlexRadio or 403a. If you could send me a link, I would really appreciate it. Ed K5YZW
Hi Ed, Here is the link:
Thank you very much, Len. I installed the 4.1.16 firmware and it works fine. I appreciate your help!
Ed K5YZW
I'm glad that was it!
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 949 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 145 Amateur Radio Interests
