AetherSDR — Open-Source Linux Client for Flex Radios
I have noticed this but this is the same with SmartSDR. Something to look at, What is your "DISPLAY" settings at for the "Rate" and "FPS" having these set at factory or to high can cause a lot of un needed network slow downs, for me I slow these settings down quite a bit from the Factory Defaults and it helps with the Network bandwidth required to run the Radio. I have my "FPS" at 10, "Average" at 15 to 20, and Waterfall "Rate" at 8
This is way easier on the eyes and not near the Network traffic.
Remember all this data needs to go over usually a 100Mb Ethernet port on the 6000 radios and most older computers and Ethernet Switch's.
Also on AetherSDR when it gets built you can change the bandwidth to "Low Bandwidth", this is in the "Setup", "Choose Radio / SmartSDR Setup" tab I think this will help a bunch of us with the OLDER computer hardware once it is implemented. This I think will really benefit many of us that use OLD computer hardware with the LINUX OS.
Bret WX7Y
I ran a test Yesterday, I ran the AetherSDR Pi AppImage 0.7.2 on my Raspberry Pi 5 8Gig Ram. It ran surprisingly VERY WELL.
On the same Pi at the same time, I also run my Node-Red server and the FreeDV-FLEX AppImage while slice A was using FreeDVU on receive on my Linux Ubuntu Intel NUC6 AetherSDR.
This I think was a vary hard stress test for the Pi5 CPU at 77, Memory at 17, Temp 177*f, In comparisons with Node-Red server and FreeDV-Flexradio, and the Node-red server running at CPU at 30, Memory at 16, Temp 120*f.
Here is a screen grab and it was consonantly a "good" Network display so the Pi graphics are being handled very well.
It is supposed to run on a Pi4 too but I have not tested that yet, maybe tomorrow.
I think a very promising portable unit.
73 Bret WX7Y
It's amazing how much power is available in the Raspberry Pi systems. My Anan G2 Saturn Ultra has a Raspberry Pi CM4 module in it. And it just cruises along with no real problems.
Of course PiHPSDR for the Anan radios is pretty light weight compared to Thetis. Or, probably compared to AetherSDR as well.
Is AetherSDR mature enough to work with the digital modes like FT8? After doing some Googling, I haven't come up with a working configuration. If I do a CAT Test that comes back green and I can change bands just fine. I have the radio set to "FlexRadio SmartSDR Slice A". I have audio input set to DAX Audio RX1 (FlexRadion Systems RX Audio). Putting WSJT-X into "Test PTT" puts the radio into XMIT, however it failes with a the "Test PTT" button coming back red after a second or two. I'm guessing there's something I'm not understanding about DAX, however I'm at a loss.
Any insight would be greatly appreciated.
73 and good DX,
de Roger, NK1I
What a great project!
I've already got it running on my Mac and Win11 with my 6400M. I tried to set it up manually via the IP address with Parallels and Ubuntu (Flex didn’t show up), but I couldn't establish a real connection to the Flex, even though it showed up then. There was no waterfall, etc.
Today, I’ll try installing it on a PI4+. I had some problems initially, but it's great to see all the improvements in such a short time.
I saw 'RADE', but I'm not sure if it's already 'activated'? It would be great to see FreeDV implemented without having to start the Flex Waveform add-on separately.
Anyway, well done. 'Slowly but surely'.
73, Stefan DF6VI
Hi,
My apologies in advance for asking such basic questions, but I am a noob at working with AetherSDR. It is on a PC running Ubuntu v24 in an AppImage.
The radio is a Flex 8600 with a TGXL and PGXL. I’m trying to get audio and rig control to WSJT-X v2.7.0-rc3 but I can’t seem to make it happen. Are there a few pointers to get me started? Here are some screen shots of what I’m seeing.
I know the port is open, because I can telnet to it and see connection confirmation in the AetherSDR UI.
Here are my audio choices in WSJT-X. None connect to DAX.
Any help is appreciated.
-73, Chuck W9WLX
OK, I figured it out. I had two mis-configs.
I needed to use Hamlib NET for the rig to get rig control.
The audio problem was due to not having an audio server installed. I installed PulseAudio with PipeWire and now have WSJT-X functioning.
Thanks for a well-done client in such a short time. Looking forward to enabling more features and continuing to experiment.
-73, W9WLX, Chuck
Do you need to uninstall a previous version every time you install a new one?
I am running AetherSDR on my MacBook. Holy Cow, this thing Rocks! And new features and bug fixes come out rapidly. de WA1QZX
I tried to copy and paste into this box and it just put it in table format and deleted a lot of text. What gives? What do I need to do to just cut and paste text?
Hi Chuck, I'm having a heck of a time getting WSJT-X or anything else working with CAT control running Ubuntu and AetherSDR (now) 0.7.12 and has me pretty frustrated so far so glad at least someone has had luck getting something working with it.
What OS are you running? 73
Bret WX7Y
I'm running Ubuntu v24.04.4 LTS. I did a fresh load of Ubuntu and had some challenges with it. Seems the driver package and the kernel had some incompatibility. The OS would not see the wireless card. When searching for a new driver, it would tell me the recommended driver is proprietary and not free. That didn't seem reasonable since it was an older Dell Latititude. Turns out I had to update the kernel, uninstall the driver package, and reinstall it. Then the wireless card came to life.
Chuck W9WLX
I actually moved away from the Issues with WSJT-X for a few hours and with Claude AI's help I built a Linux AetherSDR AppImage installer, It is at the bottom of this attached message and is called "Install_AetherSDR.sh" and it works really well the last to updates of AetherSDR we have had shared with us. This is actually a lot quicker install than Downloading and running the Windows version and the Script file below does it all in one step from a terminal screen, In fact I DID NOT have to
I ran the AehterSDR script from message #147 but it was only partially
worked and taking his Idea I built a new Script that does, as of right
now totally installs the Linux x86_386 version AetherSDR AppImage and
gives you a Desktop ICON like the windows setup version does.
To run, just copy and save the script file ONCE to your Home directory and from then on from a Terminal just type "sudo ./Install_AetherSDR.sh" hit enter from your Home directory and it should check for a update, down load the update, Install the update, and install the Icon on your Desktop program manager. To run AetherSDR just click on the Blue AetherSDR Icon.this was made for Ubuntu 24.04 but should run on other.
Bret WX7Y and Claude AI
Bret
Thanks for sharing. Jeremy KK7GWY with the sharing of his AetherSDR app has really brought back the interest in using the Flex Radio. Each day I can hardly wait to investigate and test what new features he has released. On both Linus and Windows. It is getting close to being my go to GUI for operating.
John K3MA/N2NY/VE3OI
Really excited to read this thread. It opens up some community possibilities to rethink the whole user experience and be more task-oriented.
When I operate FT8 I only look at the SSDR window to confirm there are receive signals in the passband and the transmit waveform looks right. When I contest I only look at the SSDR window to see if there are signals in the band and occasionally adjust receive filter bandwidth. WSJT or N1MM are the primary operating interfaces.
Couple features I've wanted forever: one is to "promote" a slice to A. Imagine you are listening to a pileup and tuning around the band with another slice. You hear something promising on slice C, but the logger has no visibility into anything but A and B.
Another feature I've wanted to see for years is a single client supporting two radios concurrently. Ideally it would be in the same app instance. FlexLib is built around a single radio assumption so it may not be doable without replacing the low level stuff. Two radios are better than one in my opinion because you have an online fallback if something fails in a contest.
Does anyone else think a browser based SSDR would be interesting? That potentially makes multi-radio support just into browser tabs. I haven't looked at the latest FlexLib but earlier versions had a bunch of WPF dependencies and wouldn't build under .NET.
all of a sudden my mouse wheel does not affect the tuning. Also double click the left mouse button does not affect the tuning either. v07.18.2 I even went back to v07.18 and the same thing. running Windows 11
As great as aether is, there is still a lot of wonkiness to be sorted out. I have on occasion solved problems by rebooting the computer-1
dlgver,
I already tried that I even shut the computer off rather then just a reboot. No joy. However it works fine on my Ubuntu computer and my windows 10 machine. Go figure!!
Found my problem!! My slice was locked. I unlocked it and all is good now.
I need help. I have tried to file a bug report on github but it does seem to except it.
I am just going to put it here and hope @ten98 Jeremy reads it.
SDC-Contest + AetherSDR on Linux (Ubuntu)1
Look forward to trying this out with my Flex 6700 and Ubuntu.0
you won't be disappointed I don't think, There getting it full of built in stuff and are making great head way with it, If you want to use the NEW DSP SUPER filters that most are working really well that use the Computers resources you need to plug in your station speakers into the Linux computers Speakers.
Same thing with the Windows version. The latest digital noise reduction feature works great. But, depending on your settings, the latency is noticeable. But, the receive audio on a reasonably strong signal is like full quieting FM. It will be interesting to see how it handles static crashes from thunderstorms. I will be testing that later this evening on 80 meters.
Oh one more thing Latency WILL depend on the Computer CPU, memory Hardware, and speed because the new DNS Filters are running on the Computer NOT the Radio like the other built in DNS's, So if your running on a older not very powerful computer or Laptop you may not even be able to run the DSP that reside in the computer, I have a laptop that pukes if I turn on DFNR but runs great otherwise.
I have a feeling if I move my Debian Linux install to the latest version that it will have a problem with DNFR. The current version I have doesn't have it. And monitoring system performance it shows all 4 cores ( no logical cores in the AMD Athlon 5350) running on an average of 50%. I may go ahead and try the new version just to see how much more the system will take before crashing.
It only uses resources if you enable the function, I would recommend you update to get the many bug fix's they find everyday.
I did update my Debian Linux pc with the AMD Athlon 5350 and sure enough DFNR chokes and after a few seconds looses audio. Checking System Monitor, all four cores are nearly at 100% . Turning off DFNR may or may not, bring the audio back. I have to close AetherSDR and restart it to get audio back.
I did notice one interesting thing, when using AetherSDR with my AU-520M that has the version 4.1.5 Plus/Early Access license, the RNN noise reduction in SmartSDR ( in the radio) is equal to, and slightly better than, DFNR running on my Windows 11 computer in AetherSDR. ( or SmartSDR) So, that's an indication to me how powerful the processor in the new Flex 8000 and Aurora radios are. Which, to me,is good news.
Hi,
Anybody can help me finding what is causing this behavior?
- AetherSDR v.0.8.8
- Linux
- Flex 6400M
- WSJT-X
- Hamlib Net rigctl as radio type
- Audio: aethersdr-dax1 for RX; aethersdr-tx for TX
Test CAT is ok
TEST PTT nothing happens
After a few seconds receiving, the Flex goes into TX with no audio at all. I have to close AetherSDR to stop TXing.
Paulo
Yea been to this barbeque before, the best way to do WSJT-X is the single TCI connection with AetherSDR
though programs like FLDIGI work with the DAX and CAT, WSJT-X will not with out a bunch of Audio setting customizing.
here is what to do
1: Download WSJT-X 3.0.0 Improved PLUX edition for Linux at
2: once downloaded and installed go to "File, Settings, Radio.
3: go to RIG settings and scroll clear down to "TCI Client RX1"
4: if your running WSJT-X on the same computer then set in the server to "TCI Server: 127.0.0.1:50001"
5: in that same Radio Tab set your "Split operation" to NONE", normally Flex used "Fake it" but in AetherSDR it makes the frequency walk every few transmissions.
6: Audio Tab
7: Input: set for "TCI Audio" for Output set for "TCI Audio"
8 next to Refresh make sure "Use TCI Audio"
NOW in the Radio
in the "DIGI settings" make sure TCI Server is "Enabled", and in the Radios "Setting" menu make sure "Autostart TCI with AetherSDR" is checked on.
9: Now when you Restart WSJT-X if all went well you should see one client connected on port "50001"
WSJT-X will show RX Audio but the LEVELS for TCI audio is Preset so the DAX settings in AetherSDR don't do anything but if remember right DAX needs to be enabled.
I don't think it Encodes very clean yet but each version is getting better.
Also sometime it looses the CAT information and the page will come up in WSJT-X just hit retry and it should start working.
TCI Audio actually from what I gather is using I/Q channel
This is NOT a perfect solution YET but it has been the most reliable so far and I have spent MANY waisted hours trying to find a better way before TCI was activated.
73 and hope this helps
Bret WX7Y
- 392 Community Topics
- 665 The Flea Market
- 171 SmartSDR+
- 446 SmartSDR for Mac
- 266 SmartSDR CAT
- 210 DAX
- 387 SmartSDR API
- 66 Aurora
- 310 FLEX-8000 Signature Series
- 979 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
