6400M has temporary distortion on strong receive signals before it self adjusts/
While answering an email, I heard my 6400M audio go up in volume and change tone. I looked at the screen and it appeared the AGC-T was running amuck. The window that opens when you adjust the AGC-T was visible and the #s were rapidly going up. I turned the knob and it stopped but the audio was distorted. I went into all my settings and could not correct the audio. I had to do a hard reboot. When the Flex rebooted, my saved profiles were no longer available so I went in and reset everything to acceptable levels with one problem. Strong stations are distorted for a second or 2 until, what I think is happening, the AGC finally adjusts that level to stop the distortion. Any suggestion on what setting I am missing that could be causing the distortion? It is NOT the AGC-T. My receive audio EQ is set to where it was prior to the hard reboot. (I have several cell phone pics I took of screen savings)
I would save your profiles on your PC, reset the radio and then test again. If the problem doesn't resurface, then import your profiles and see if the problem comes back.
Do you have any software programs communicating with the radio?
Are you using MultiFlex?
This will help isolate the issue.
Mike,
I thought I had saved my profiles to my computer, twice. The radio is not finding them. Not that big of a deal as I made notes and photos of most of the settings I have running. I have not had the run-a-way audio since but I have done 2 hard reboots with no joy on the temp distortion of strong signals. I have the Flex connected to my computer but I have no programs currently running with it. Let me emphasize that I am not sure it was the AGC-T that was the problem. When I looked that the Flex screen, I saw the same white window you get when you adjust the AGC-T, Low Shift, High Width knobs. The value was rapidly increasing on its own. I was not operating the radio at the time, I was just monitoring the band. Until I hard rebooted, both the High and Low numbers did not correspond with the audio I was hearing.
Still have not found a setting or combination of settings that stopps the problem
Has anyone had this problem? Any signal on 20 meters that is 5-9+ starts of muted, becomes distorted and then is fine. It takes a a second or two to go from the extreme to readable.
Evening Mike.
Was wondering if ever resolved this issue with your 6400M. Seems mine has been doing the same thing for a few years now and getting worse. I sent in a ticket, but that news sounded expensive. Any help appreciated.
7 30 -
I notice it at times when the NB is on. Turned it off,and it solves the issue. I had this occur on other radios I have owned and accept it as normal operation. Again this is just on very strong signals.
-1 -
I have a new 8400 running the latest software. This always happens when I have NB enabled and receiving a string signal. The signal is initially distorted and then clears up after a few moments as has been described. Turning off NB solves the problem. I would be very grateful if Flex looked into this too.
This has been this way for many years, there are a couple 3rd party Programs that allow you to make the DSP filters not so aggressive, You may want to submit a support ticket to Flex though an see if they may tell you anything.
Better yet, there is also a 3rd party Linux and multi-platform (Windows, Pi, and MAC) program called "AetherSDR" that also has sliders that has been out for a few weeks that runs really well so far that runs on all the 6000 / 8000 / Flex Radios instead of SmartSDR, I have even ran it on a Raspberry Pi 4 and Pi 5.
On Windows to do FT8 Flex DAX and CAT work well with AetherSDR if your wondering about sound card type Programs.
Bret WX7Y
- 392 Community Topics
- 665 The Flea Market
- 171 SmartSDR+
- 446 SmartSDR for Mac
- 266 SmartSDR CAT
- 210 DAX
- 387 SmartSDR API
- 66 Aurora
- 309 FLEX-8000 Signature Series
- 979 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
