Yellow "TX" button in DAX
You need to turn on DAX for transmit:
That got it, at least my FT8 is working. Still no VaraHF though. Thoughts?
And how do I save this config. Does the profile save everything?
That is part of your Mic Profile. I have the following mic profiles (just to give you an idea of what you can do):
Len CM500 - for my Yamaha CM500 headset Len FHM-3 - for the stock hand-mic that came with my rig LenDigital - for VarAC (DAX on) Len HM-12 - for my Heil mic (PROC on) Len HM-12 FM - for my Heil mic when I operate FM (PROC off) Len Laptop - for my laptop mic when I am operating remotely
Go to Profile Manager and select the Microphone tab. There you will be able to create any Mic Profiles that you want. When you have a profile selected, any changes you make to the mic characteristics (DAX, PROC, MON, Mic Level, etc.) and TX equalizer will be automatically saved unless you turn off auto-save.
As far as VarAC goes, in the VARA HF settings, choose these DAX input and output devices:
In VarAC Settings, Rig Control and VARA Configuration, select SmartSDR for PTT and Frequency Control. Select TCP for CAT Configuration and the values I show below for Host and Port.
There are probably other things that I am not thinking of, but that should get you started.
Good info on Mic's. Tnx.
Im using VARA HF. Not same screens regretfully..
VARA HF is just the HF modem. VarAC is the communication program that uses VARA HF.
Here is a link:
On my old radio (IC7300) I used Winlink and VARA hF, nothing more.
Ah, Winlink. I thought you were trying to use VARA HF by itself.
Thank you all, I got it working !! Just in time for the Wyoming Winlink exercise….
Working, yes but…. I have RF slider to 100 so why doesnt it shove out 100W? Im only getting 50 to antenna. ??
