Yellow "TX" button in DAX
Ruarto
Ruarto Member ✭✭
I have been following N4VER UTube video on setting up WSJT-X with my Flexradio 8600M
All seems good except it still doesnt work. In the DAX app the yellow "TX" button stays yellow and never goes to "streaming". I obviously missed something.
    You need to turn on DAX for transmit:
  • Ruarto
    Ruarto Member ✭✭
    That got it, at least my FT8 is working. Still no VaraHF though. Thoughts?
    And how do I save this config. Does the profile save everything?
    That is part of your Mic Profile. I have the following mic profiles (just to give you an idea of what you can do):
    Len CM500 - for my Yamaha CM500 headset
    Len FHM-3 - for the stock hand-mic that came with my rig
    LenDigital - for VarAC (DAX on)
    Len HM-12 - for my Heil mic (PROC on)
    Len HM-12 FM - for my Heil mic when I operate FM (PROC off)
    Len Laptop - for my laptop mic when I am operating remotely
    Go to Profile Manager and select the Microphone tab. There you will be able to create any Mic Profiles that you want. When you have a profile selected, any changes you make to the mic characteristics (DAX, PROC, MON, Mic Level, etc.) and TX equalizer will be automatically saved unless you turn off auto-save.
    As far as VarAC goes, in the VARA HF settings, choose these DAX input and output devices:
    In VarAC Settings, Rig Control and VARA Configuration, select SmartSDR for PTT and Frequency Control. Select TCP for CAT Configuration and the values I show below for Host and Port.
    There are probably other things that I am not thinking of, but that should get you started.
  • Ruarto
    Ruarto Member ✭✭
    Good info on Mic's. Tnx.
  • Ruarto
    Ruarto Member ✭✭
    Im using VARA HF. Not same screens regretfully..
  • Ruarto
    Ruarto Member ✭✭
    On my old radio (IC7300) I used Winlink and VARA hF, nothing more.
    Ah, Winlink. I thought you were trying to use VARA HF by itself.
