Flex 8400M
Hi Everyone..
I,m fairly new to the 8400M having changed from the 5000A.
The radio boots up ok and asks me to update, which I have done .
When I open SMARTsdr, it asks me to update which I agreed it then does seemingly exactly the same update as I did 10 minutes before.
How can I get SMARTsdr to connect with the 8400M in order to run Smartcontrol on my PC (win10 Pro)…… I dont need Smartlink
Roger G0IUW
    Roger
    It sounds like you are running the wrong version. Look closely at the shortcut and make sure the version number matches the version installed on the radio.
  • Roger
    Roger Member ✭✭
    OK Mike thanks…
    what next?
    8400M bbots up in "standalone" mode……..I open Smartsdr…..display shows "8400m in use"……..
    and yellow box shows "disconnect"
    Not sure what to do next?
    Roger G0IUW
