Flex6400 and Maestrao C together
You can do that. It is called Multi Flex.
Yes, DAX and CAT will work as well.
- SSDR/Smart link connect to your FLEX-6400 over SmartLink - Slice A
- Do the same with the Maestro C - it will show up as Slice A - that sounds confusing, but it is a different Slice A as it is Slice A on the Maestro
- With DAX and CAT, which I assume is on the same PC, you have to tell it which client to use.
Give it a try and you should be able to sort it out pretty quickly.
Leif, Flex sees those as two "operators" at two separate locations, so they each start with their own Slice A.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 980 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 832 Peripherals & Station Integration
- 145 Amateur Radio Interests
