Flex6400 and Maestrao C together
You can do that. It is called Multi Flex.
Yes, DAX and CAT will work as well.
- SSDR/Smart link connect to your FLEX-6400 over SmartLink - Slice A
- Do the same with the Maestro C - it will show up as Slice A - that sounds confusing, but it is a different Slice A as it is Slice A on the Maestro
- With DAX and CAT, which I assume is on the same PC, you have to tell it which client to use.
Give it a try and you should be able to sort it out pretty quickly.
Leif, Flex sees those as two "operators" at two separate locations, so they each start with their own Slice A.
- 407 Community Topics
- 705 The Flea Market
- 205 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 983 Genius Products
- 328 Shack Infrastructure
- 233 Networking
