Flex6400 and Maestrao C together
LA9BM
LA9BM Member ✭✭
I want to operate my Flex6400 on slice A and Maestro C on slice B. Different band/mode. The Flex6400 is on a remote QTH and today I only use 1 slice.
Will it work or do I need a 3rd parity program? What about DAX and CAT?
Thank you from LA9BM, Leif
    Answer ✓
    You can do that. It is called Multi Flex.
    Yes, DAX and CAT will work as well.
    • SSDR/Smart link connect to your FLEX-6400 over SmartLink - Slice A
    • Do the same with the Maestro C - it will show up as Slice A - that sounds confusing, but it is a different Slice A as it is Slice A on the Maestro
    • With DAX and CAT, which I assume is on the same PC, you have to tell it which client to use.
    Give it a try and you should be able to sort it out pretty quickly.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Leif, Flex sees those as two "operators" at two separate locations, so they each start with their own Slice A.
