How do I tune ?
The radio has been replaced by Flexradio!! I now have my 8600M radio being seen by the PC and wow, finally I am hearing some activity on the air. I have not yet transmited. Soon I hope. Old questions answered still here on my activity page so I like being able to go back and refer to them !!
So a couple questions.
  1. when the freq is off scale is there a faster way to move the tuning line to where I want it? Rolling the mouse wheel takes forever.
  2. And most importantly, how do I make that internal tuner do its thing? is there a button Im not seeing to make it tune to the freq Im at?
  • Ruarto
    Ruarto Member ✭✭
    I found the answer to the tuning issue. manual helped, peeking around better.
    I think my antenna is too far out of tune for the radio tuner to handle. Is there a way to test that or see it on screen? My guess is antenna is SWR of 5 to 7, Radio can only handle up to 3. Right?
  • Trucker
    Trucker Member ✭✭✭✭
    #1. You can use touch tuning by double tapping in the spectrum display near the frequency you want to tune to. Then, fine tune with the vfo knob.
    #2. There is a Tune button below the one Low/High knob. And an ATU button to the right of it to put the tuner inline or bypass.
  • Ruarto
    Ruarto Member ✭✭
    My operation seems to be only from the pc. None of the buttons or display or the radio are on.
    Is there a way to have both the pc and the radio and be in sync ?
    I havent figured out yet how to switch operation from the pc to the radio itself.
  • Trucker
    Trucker Member ✭✭✭✭
    Turn the tune power down very low. Then touch the meter in the upper left of the screen until it says SWR. Then when you key the radio using the Tune button the meter should indicate what SWR it is seeing. Depending on what antenna you are using, you may need an external tuner with a wider tuning range. That, or use an antenna analyzer to fine tune your antenna if it isn't setup properly for the band you are wanting to operate on.
  • johnn1jm
    johnn1jm Member ✭✭✭
    Ruarto- can you take a picture of the front of your Flex radio and post it?
  • Ruarto
    Ruarto Member ✭✭
    radio all dark, no buttons lit or will light, screen blank. only seeing things on the pc.
  • Ruarto
    Ruarto Member ✭✭
  • johnn1jm
    johnn1jm Member ✭✭✭
    Have you tried to turn your radio off for a minute or two and then back on? If that doesn't work, you should try factory reset.
  • Ruarto
    Ruarto Member ✭✭
    Here is pic of pc screen. Perhaps more meaningful? Still dont know how to turn on the screen etc on the actual radio.
  • Trucker
    Trucker Member ✭✭✭✭
    Has the screen ( front panel) never worked? If not, you need to open a Help Desk ticket and get Flex Radio to check it out. It shouldn't be completely blank even if you select " Disconnect " when starting SmartSDR on your computer.
  • Ruarto
    Ruarto Member ✭✭
    When I first turn the 8600M on and let it boot I do get some full screens on the radio. I can tune, but cannot find how to change bands.
    We have a bunch of new user videos here that you might want to grab a beverage and watch. It will give you a great overview.
  • Trucker
    Trucker Member ✭✭✭✭
    Mike's videos are a great help getting going if you are new to the Flex radios.
  • johnn1jm
    johnn1jm Member ✭✭✭
    Touch the frequency on the radio screen. You will see all kinds of items to change. In the middle there are all the bands. Touch one of them and that will change you to that band. Touch the frequency again to go back. Have you downloaded the manual from the Flex web site? You should try to read it. There is no manual per se for the 8600M but download the one for the 6400M/6600M unless it has been updated recently. In that manual most all pertains to the 8400/M and 8600/M. And as Mike said look at those videos.
