Automatically place PGXL in BYPASS for certain bands
ChrisNia
Is there a way to automatically place the tuner in BYPASS for certain bands? I am using an outdoor tuner for certain bands and it would be helpful if the TGXL automatically went into standby for those bands so the outdoor tuner can do its thing.
Not really. You could build some NodeRed flows that could do it.
If you want the tuner to bypass on specific bands you can go into the tuner settings, select the Other option and then select band configurator option. It allows you to designate bypass frequencies for each antenna on each band.
That is an even better idea!
remember the start and stop bypass frequency is entered in kHz. (14305.000)
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
