Automatically place PGXL in BYPASS for certain bands
ChrisNia
ChrisNia Member ✭✭
edited 2:45PM in SmartSDR for Windows
Is there a way to automatically place the tuner in BYPASS for certain bands? I am using an outdoor tuner for certain bands and it would be helpful if the TGXL automatically went into standby for those bands so the outdoor tuner can do its thing.
    Not really. You could build some NodeRed flows that could do it.
  • Rick N4RZ
    Rick N4RZ Member ✭✭✭
    If you want the tuner to bypass on specific bands you can go into the tuner settings, select the Other option and then select band configurator option. It allows you to designate bypass frequencies for each antenna on each band.
    That is an even better idea!
