Fine Power Setings
HB9DDS
Flex-6400 (Stand alone)
Is it it any way possible to set the power in 100mW steps?
For example 1W / 1.2W / 1.4W / 1.6W / 1.8W / 2W
Daniel
HB9DDS
Hi Daniel, the radio only changes in 1 percent increments, so that is a 1 watt resolution on the 6400.
For low power finer increments, you could use a step attenuator. Another possibility is a small amp connected to the transverter port. You can change the port output in fine increments.
That's what I thought. Too bad. They could easily change that with an update...
Daniel
HB9DDS
- 322 Shack Infrastructure
- 227 Networking
