Fine Power Setings
Flex-6400 (Stand alone)
Is it it any way possible to set the power in 100mW steps?
For example 1W / 1.2W / 1.4W / 1.6W / 1.8W / 2W
Daniel
HB9DDS
Hi Daniel, the radio only changes in 1 percent increments, so that is a 1 watt resolution on the 6400.
For low power finer increments, you could use a step attenuator. Another possibility is a small amp connected to the transverter port. You can change the port output in fine increments.
That's what I thought. Too bad. They could easily change that with an update...
Daniel
HB9DDS
- 409 Community Topics
- 705 The Flea Market
- 206 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
