DAX Driver Error
Flex-6400M, Windows 11
I don't like doing this, but since I haven't received an answer or solution in six months, I'm trying again.
When I start DAX, I get the following error message.
I can't find the cause. The help desk couldn't answer it either...
Daniel
HB9DDS
  • David Decoons, wo2x
    usually that happens when the computer tries to grab one of the DAX drivers as a default record or playback device.
    Try setting the TS480 as default record device and the high definition audio device as default playback device. or if you have a USB PC mic, plug that in and set to default record device.
    Reboot then follow this procedure to reinstall DAX drivers.
    https://helpdesk.flexradio.com/hc/en-us/articles/41413843097883-How-to-Manually-Reinstall-the-DAX-Drivers
    73 Dave wo2x
    This is a fixable problem. If you open a support ticket they should be able to sort you out.
  • HB9DDS
    HB9DDS Member ✭✭
    edited March 1
    @ Dave, W02X
    I've done this so many times. Also this afternoon (again). No success
    Oh yes, I opened a ticket on October 28, 2025. But they had no solution and gave up...
    I reinstalled SmartSDR on a new Windows 11 partition. It works perfectly there.But what's causing the problem?
    Daniel
    HB9DDS
  • HB9DDS
    HB9DDS Member ✭✭
    There might be an entry somewhere in the registry. Does anyone know more about this?
    Daniel
    HB9DDS
    Daniel… this is not something to go guess about at. Open a ticket and let the guys who deal with our products on a daily basis help you out. They are the best in the world at it and it is free.
  • HB9DDS
    HB9DDS Member ✭✭
    @ Mike
    I already opened a ticket last year. No luck. The helpline "gave up".It's pointless for me to do it again. It's very frustrating.
    Daniel
    HB9DDS
    Not sure why. This is a very solvable problem. Usually.
    I had a weird problem with Icom's drivers when I could not use CAT on my IC-9700 and I had to actually rebuild windows from scratch. Given the many hours I tried to get to the root cause of the 9700 issue I have learned that sometimes you need to just reinstall Windows as it is confused. And, the solution is a Windows solution, not an vendor solution. It seems that this is what has happened in this case. Of course, calling Microsoft can be painful as well.
    I found that rebuilding the entire computer was great for helping me de-crapify it! :) In the end, it was worth it.
    I gather that this problem is just with 1 computer?
  • HB9DDS
    HB9DDS Member ✭✭
    edited March 7
    Okay, I've found the solution 😍
    I forgot to do the blue arrow thing.
    I only did the red arrow thing.S orry for the fuss...
    My bad 😱
    Daniel
    HB9DDS
  • ny6e
    ny6e Member
    edited March 12
    I was having difficulty installing 4.1.5 on an older Windows 10 laptop that I use in the field. All updates were current and I removed lots of older apps. During several installation attempts I got the blue screen of death, and other times it had DAX Driver errors. So after reading your post, I invoked the installer using "Run As Administrator" and it worked just fine.
