Smartlink IPV4/IPV6 Dualstack failure
Hello!
With Smartsdr 4.1.5 I can no longer log in with Smartlink.
Here in Europe, dual stack IPv4/IPv6 is now common.
The SmartLink login tries to call cdn.auth0.com, this is done via IPv6, because an IPv4 and an IPv6 address are returned and then it does not continue.
If I turn off IPv6 it works again.
Either you now finally introduce IPv6 or you take out the close resolution AAAA cdn.auth0.com.
73, Hardy
I agree 100%, @Hardy
For name-resolution, my configured first choice is always IPv6, with IPv4 playing second-fiddle as a fallback alternative.
For over a decade in my home-network, I've used IPv6 for services like LDAP-auth, NFS, NTP, backup, web-servers, etc. I like to set the last few bit of the IPv6 to match my IPv4, so I don't get confused 😂 Even my own small, personal web-servers, blogs, etc are IPv6 compliant and world-accessible.
I'd love for Flex to support this tokenized IPv6, allowing a fixed trailing-portion of the address, with a changeable first-portion (SLAAC, DHCPv6, etc). Maybe, maybe we could then get rid of UPnP, port-forwards, etc for SmartLink. The Dream is Alive 🤣
If you have not opened a support ticket for this, please do.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
