Smartlink IPV4/IPV6 Dualstack failure
Hello!
With Smartsdr 4.1.5 I can no longer log in with Smartlink.
Here in Europe, dual stack IPv4/IPv6 is now common.
The SmartLink login tries to call cdn.auth0.com, this is done via IPv6, because an IPv4 and an IPv6 address are returned and then it does not continue.
If I turn off IPv6 it works again.
Either you now finally introduce IPv6 or you take out the close resolution AAAA cdn.auth0.com.
73, Hardy
I agree 100%, @Hardy
For name-resolution, my configured first choice is always IPv6, with IPv4 playing second-fiddle as a fallback alternative.
For over a decade in my home-network, I've used IPv6 for services like LDAP-auth, NFS, NTP, backup, web-servers, etc. I like to set the last few bit of the IPv6 to match my IPv4, so I don't get confused 😂 Even my own small, personal web-servers, blogs, etc are IPv6 compliant and world-accessible.
I'd love for Flex to support this tokenized IPv6, allowing a fixed trailing-portion of the address, with a changeable first-portion (SLAAC, DHCPv6, etc). Maybe, maybe we could then get rid of UPnP, port-forwards, etc for SmartLink. The Dream is Alive 🤣
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIf you have not opened a support ticket for this, please do.
I suspect this is my issue with My Mac version of SmartSDR not connecting with my 6600 and my new AT&T wireless streaming and internet.
I've found a workaround on the Windows side of SSDR, which is to directly connect the radio to my machine, then using wireless for internet. But on the Mac version of SSDR, the radio doesn't connect if you try going direct ethernet. Anyone found a workaround?
-1
- 418 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
