Aurora Arrived
tnx for comments; don't mind paying for the early access but the knob is still getting stuck at around 6-7 o'clock position it does NOT feel the same as the 8600M just frustrating that ALL THREE of my radios had problems; 6600M front speaker was dead 5 years ago; 8600M had terrible fan noise and now this; such is life bigger problems to deal with; anyway tnx for comments; do i have the power set up correctly it's @100% and only getting 100 watts out; tnx for info
**** question is FRStack third party software; not familiar with it tnx
Yes ,FRStack is a 3rd party application. It has a lot of useful features and once you get used to it,, you will wonder how you ever got along without it.
FRStack - My ASP.NET Application https://share.google/ugt0DZmsw6G2n7rph
Maybe you can pull the knob slightly towards you and take pressure off of whatever is causing it to bind up. But, to be on the safe side, I would still suggest opening a Help Desk ticket.
did that and was told to take the rubber ring off first then remove the VFO knob and look for a loose piece of tape holding onto a counterweight; great start for a new radio HIHI
I remember reading something about removing the rubber ring now that you mention it. I hope you didn't damage anything if you tried my suggestion first!
I hope the correct procedure fixed the problem for you.
will try this weekend tnx for info
did the rubber ring and counterweight was still taped to the knob; everything worked last night at home did not realize that 100% power output = 500 watts; nowcan't log into from my xyl appartment
8600M is obvioulsy in watts not percentage; i will check monday re home network
Yes, the 8600M power output displays in watts. The Aurora displays percentage. But, there is a meter display for the Aurora that shows up to 600 watts. Plus, PA temperature and power efficiency. It is selectable from the top row of tabs.
I am glad you found the problem with your VFO. Someone must have been in a hurry assembling the radio and overlooked that.
tnx now i have to wait until moday cant log into aurora remotely; the counterweigjt was installed correctly with tape so just reinstallled it NOT quite fully back on the radio; tnx will probably have to reboot tnx
just wanted to thank everyone re advice; forgot i had to register the 520M re smartlink and it is a little different from the 6600M/8600M it is done directly from the radio and then hit the PTT on the mike; was on 40M AM and now have to play with the microphone for best audio settings; will try out the noise limiting software the the ADP as well;
- 384 Community Topics
- 641 The Flea Market
- 147 SmartSDR+
- 436 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 935 Genius Products
- 343 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
