SmartSDR issues or Radio issues (FLEX 8600)
it could be SmartSDR or the GPSDO that was installed during the build. My Radio is going down and back up by its self. It will be triggered by most the time when I select different band I will get alert that SmartSDR has lost connection to the radio. I'm running 3.9.18. the Radio will reboot and it could happen again right after the reboot. This is odd for sure. I can't find the correct thing I'm doing but always changing bands.
Jim
WU5E
    Hi Jim, I would do a profile export, then do a factory reset. If that doesn't solve it issue, submit a help desk ticket.
  • n0ypd
    n0ypd Member ✭✭
    I just turned the smart link off on my 8400m. Didn't need it on,and the disconnect issue went away of course.
  • James Kennedy-WU5E
    James Kennedy-WU5E Member ✭✭✭
    Network Diagnostics
    Network status: Excellent
    Latency: <1ms
    Max Latency: 111ms
    Remote TX 0
    Remote RX 0
    Dropped 6 out of 2330300 packets 0.0%
    Network is good network is Starlink Home
    The Radio acts like a pageant woman the first time I turn it on at 0530 it blues up with the GPSDO in it I start SmartSDR 3.9.18 and I select 6m this morning good CW contact and the Radio reboots I get up and walk into the kitchen for coffee. 3 minutes later I walk about the Radio room and sit down with my coffee. It stays up the rest of the day
    Jim
    WU5E
    I did do a factory Reset
  • Ken Wells
    Ken Wells Community Manager admin
    Be sure that when doing a Factory Reset, that you leave the "Preferences" box UN-CHECKED when you export or import your profiles. This resets the Radio Persistence Database, which is often where the issues "hide."
  • Scott Lewis
    Scott Lewis Member ✭✭
    a { text-decoration: none; color: #464feb;}tr th, tr td { border: 1px solid #e6e6e6;}tr th { background-color: #f5f5f5;}
    Resolved Issue: FlexRadio 8600 Rebooting and SmartSDR Blank Panadapter
    After carefully monitoring when the radio rebooted and completing the full factory‑reset process typically recommended to resolve this behavior, I identified that the root cause was related to a small number of corrupted profiles. I wanted to avoid rebuilding all of my Mic, TX, and Global profiles from scratch, so I continued troubleshooting until I discovered a consistent pattern.
    Ultimately, I found that two Global Profiles were repeatedly triggering either:
    • A full reboot of the FlexRadio 8600, or
    • A blank panadapter (PAN) display within SmartSDR.
    Deleting only those two problematic profiles and recreating them resolved the issue completely.
    Detailed Procedure
    1. Exported all radio settings before making changes.
    2. Performed a full factory reset, following the steps documented by Tim Ellison in the “How to completely reset an Aurora/Flex‑8000/6000” guide.
    3. Imported only “Custom” profiles, specifically:
      • Global Profiles
      • TX Profiles
      • Mic Profiles
        I did not import any built‑in/default profiles.
    4. Did not import Memories, since those can be reviewed easily via the Excel‑format export.
    5. Did not import:
      • Preferences
      • TNFs
      • XVTR settings
      • USB Cable configurations
    6. Identified two Global Profiles that consistently caused either radio reboots or SmartSDR display issues.
    7. Deleted those two profiles, then recreated them manually based on working profile copies.
    8. After these steps, the radio has been stable with no further issues.
  • Scott Lewis
    Update: After doing a factory reset of my Radio, I then imported, deleted, and recreated the profiles that were causing the Radio to reboot. This process worked for a while, but then I started seeing profiles cause reboots again, and the radio would just randomly reboot. I performed a factory reset and spent half a day rebuilding all my mix, TX, and global profiles from scratch. ** (That was not good) from scratch.) ** Flex, you are going to have to get this fixed. Just doing version upgrades that require you to rebuild your Radio from scratch is NOT a good thing.
