Aurora Arrived
2»
  • Arnold Goldman
    Arnold Goldman Member ✭✭
    tnx for comments; don't mind paying for the early access but the knob is still getting stuck at around 6-7 o'clock position it does NOT feel the same as the 8600M just frustrating that ALL THREE of my radios had problems; 6600M front speaker was dead 5 years ago; 8600M had terrible fan noise and now this; such is life bigger problems to deal with; anyway tnx for comments; do i have the power set up correctly it's @100% and only getting 100 watts out; tnx for info
  • Arnold Goldman
    **** question is FRStack third party software; not familiar with it tnx
  • Trucker
    Trucker Member ✭✭✭✭
    edited February 12
    Yes ,FRStack is a 3rd party application. It has a lot of useful features and once you get used to it,, you will wonder how you ever got along without it.
    FRStack - My ASP.NET Application https://share.google/ugt0DZmsw6G2n7rph
  • Trucker
    Trucker Member ✭✭✭✭
    Maybe you can pull the knob slightly towards you and take pressure off of whatever is causing it to bind up. But, to be on the safe side, I would still suggest opening a Help Desk ticket.
  • Arnold Goldman
    did that and was told to take the rubber ring off first then remove the VFO knob and look for a loose piece of tape holding onto a counterweight; great start for a new radio HIHI
  • Trucker
    Trucker Member ✭✭✭✭
    I remember reading something about removing the rubber ring now that you mention it. I hope you didn't damage anything if you tried my suggestion first!
    I hope the correct procedure fixed the problem for you.
