Not connecting to SmartLink
My laptop crashed and I reloaded everything that I had before. I installed V4.0.1 because that is what my FLEX 6600M is using. Somehow the software did not load the FLEX VSP.drivers. Now I get a nasty message telling me that CAT will not work because I don't have those drivers. I looked in my "PROGRAMS & FEATURES" and those drivers are not there. So what is a mother to do???? I am using AT&T fiber Gatway that does not have UPnP, so I have to go into Gaming/Nat in the Gateway and setup port forwarding. I named it FLEX 6600 for TCP 4993-4994 and FLEX6600M for UDP 4993-4994. I still can't connect to SmartlLink. When I do the TEST that is in the window of SmartSDR, it fails I get a RED dot.
Thanks, Bob W6MTM (w6mtm@verizon .net)
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIt looks like your settings are wrong. Automatic setup is the better way if your router support uPNP and it is turned on.
UDP should be 4993-4993
TCP should be 4994-4994
The VSP drivers are not part of SmartLink and the network and are a totally different problem. SmartLink is only required for remote HF operation.
I would recommend you open a support ticket.
- 686 The Flea Market
- 195 SmartSDR+
- 102 Aurora
- 994 Maestro
- 971 Genius Products
- 357 Tuner Genius XL
- 133 Antenna Genius
