Band Switch Kaput
I’m using a 6400M, and while the Band button works for selecting bands from 6 to 40 meters, choosing 60, 80, or 160 meters only zooms in—the Slice Receiver doesn’t appear. Has anyone else experienced this? To operate on 60, 80, or 160 meters, I must open a Slice and manually enter the frequency.
THX
Dereck
  • DBC
    DBC Member ✭✭
    Answer ✓
    Thank you, a reset fixed it. Ironically, the problem started when I updated to SmartSDR 4.1.5
    Hi Dereck, you might want to try a factory reset. Be sure to export your profiles first.
    I would do what Len said, but first update to SmartSDR 4.1.5 as well.
