Missing Flag Parts
Hi folks-
I just installed 4.1.5 on Windows 10 and it’s working fine, however, the bottom part of the flag is missing. Any thoughts how to fix this (see photo)?
Scott
W0SJE
Hi Scott, it looks like a font issue, but you might want to try a factory reset to see if that fixes it. Be sure to export your profiles first.
How bad is the snow at your house? We have enough to cover the streets, but otherwise it's not too bad.
You may have tried this but click on A then click on A again. Probably not the cure but something simple to try.
Check this link for more info:
https://community.flexradio.com/discussion/comment/20480678#Comment_20480678?utm_source=community-search&utm_medium=organic-search&utm_term=font
Thanks for the suggestions guys.
I installed the fonts and took down the windows font size (per the article) and it looks like that fixed it.
Len-
We’ve had a few inches over the last few days, but the cold below zero has been the real issue. It ended up being a great weekend for Winter Field Day.
Scott
- 681 The Flea Market
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
