Setting up UDP with SDC
I'm running SmartSDR 4.1.3. I ran into the "Slicemaster no longer works" problem, so I downloaded SDC.
I am not using SmartLink, I don't operate remotely.
In SDC's SmartSDR API tab, I am able to connect the TCP port, but the UDP port shows the two link halves as green but they are not connected.
How do I set up a UDP port on SmartSDR so that the UDP connection succeeds? I did set up the TCP and UDP ports in my Windows Firewall, but I may not have done it all correctly.
Thanks for your help!
Claudia de W7OMM
Before you worry too much about the UDP port, ensure that you have actually defined a Skimmer first.
Without this, there is nothing to use the UDP link. If you do already have a Skimmer set (and it is not working because of UDP failure), try different UDP port numbers. Some are in use and hence cannot be used.
Here, I use 4999 because other ports are not available to me
Got it, that could be the whole problem, since I haven't defined a skimmer. I'll set that up tomorrow - thanks much!
- 691 The Flea Market
- 197 SmartSDR+
- 462 SmartSDR for Mac
- 114 Aurora
- 979 Genius Products
- 136 Antenna Genius
- 323 Shack Infrastructure
- 228 Networking
