FRStack V4.0.0.1 Released
Version 4.0.0.1 of FRStack for Windows and FRStack Web APIs for Windows, RPi, Linux and OSX has been released.
Updates and Changes
Update to FlexAPI 4.1.5
Add Slice DSP: NRL, NRS, RNN, NRF ANFL, ANFT
Add Slice ESC, ESCGAIN, ESCPHASESHIFT
Add Slice FMTX1750 for EU
Download link: http://www.MKCMSoftware.com/download/FRStack4Setup.exe
This release replaces FRStack3, it supports version 3 and 4 radios.
If you upgrade FRStack3 the install folder will remain FRStack3 else it will be named FRStack4.
Expose FRStack REST APIs to your network
- Edit FRStack.exe.config file in the "C:\Program Files (x86)\FRStack4" folder then change the following to expose REST to the network.
Change
to
Now when FRStack executes it will be available to your network. You now must run FRStack as Administrator OR register the REST port with Windows.
I recommend that you add a URLACL for the PORT for any Windows User that runs FRStack.
You register the port with NETSH by running the following command in a CMD window launched as Administrator. Note the default port for FRStack is 13522.
netsh http add urlacl url=http://+:13522/ user=everyone delegate=yes
FYI:
You can list registration via: netsh http show urlacl
You can delete this registration via: netsh http delete urlacl url=http://+:13522/
What is "FRStack Web APIs"?
This version of FRStack provides REST APIs for RADIO, SLICE, UDP, PGXL AMP, SPE AMP, SteppIR Control for the Raspberry PI (ARM32) , Linux (x64), Windows and OSX (x64) platforms.
73, Mark W3II
Thanks Mark! It is great to have you as part of the group.
Merry Christmas!
How do you get the new commands, i.e. to turn on NRS, to show up in Stream Deck?
I am assuming you have the proper licensing on your Radio that enables new DSP features.
For FRStack UI, Right click on slice display then select DSP menu item.
You could also add global hotkey in FRStack that toggles the DSP features on and off. Find this under View Hotkey Editor. once you add your hotkeys remember to select the View Hotkeys to enable them.
For STREAMDECK
In the FRStack installation directory there is a new
com.mkcmsoftware.restcall.streamDeckPlugin. Install folder may be FRStack3 or FRStack4.
Open the Streamdeck editor then right click on a FRStack item then select uninstall.
Next step is to load the new plugin by double click on the new plugin you found in the installation directory. You should see a message box confirmation in the Streamdeck editor.The installation folder also holds stream deck profiles to which I have added the new features.
"C:\Program Files\FRStack3\FRStack SD+.streamDeckProfile" has a new page with DSP additions.
"C:\Program Files\FRStack3\FRStack4 Rest.streamDeckProfile" has a new DSP+ under DSP folder.73, Mark W3II
Yes, I am a SmartSDR+ Early Access Subscriber.
…and thank you for the quick reply, that worked! I added NRS to my Stream Deck.
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
