8400M + external Maestro?
Hi
I consider purchasing my very first Flex, but I have some doubts which one I shall choose.
I wish I knew is it possible to use e.g. the 8400M ATU series + another Maestro interface panel connected either to the main unit itself via LAN or Wi-Fi, or as a remote panel to manage my station remotely? Or I rather should choose 8400 ATU + external Maestro?
Thanks for your answer in advance
73! Stan
Best Answers
  • n0ypd
    n0ypd Member ✭✭
    Answer ✓
    Hi Stan,to answer the atu question. I jujust installed the tuner in my 8400m a few weeks ago,and found it very easy to install.
  • Arnold Goldman
    Arnold Goldman Member ✭✭
    Answer ✓
    I've always had an M model at home as well as a maestro; started with an 6600M and maestro B now have 8600M I am OLD FASHIOJED and like playing with knobs in front of me rather than on a computer; I have a maestro that I leave at my xyl apartment in manhattan; and a C i have in the office; if you like to have a real radio in front of you and NOT have to rely on a computer go with an M model AND A MAESTRO for remote; as a noted just got back my tgxl from FLEX so hopefully can now run the tuner AND AMP remotely too; hope that answers you question;
    Hi Stan, it depends on what you want to do. If you want front panel control from two locations and don't mind moving the front panel from one location to the other, a non-M version plus a Maestro would work great.
    If you have a home station and a permanent remote location that you want to always have ready, an M model at home plus a Maestro at the remote location would be very convenient.
    A non-M model and a Maestro at home and another Maestro at the remote site would give you the ultimate in flexibility.
  • sp8s
    sp8s Member ✭✭
    Hi Len
    Thanks so much for your very informative answer and replying this fast :-)
    Ok, so if I understood correctly, I can use Maestro with e.g. 8400M ATU, both locally and remotely. Correct? Like having 2 synced Maestro displays at my shack + an option to take one to operate from another place.
    One more question. If I purchase a Flex without ATU, and one day I decide to buy the ATU unit, can I install it later on my own?
    Greeting!
    Stan SP8S
  • sp8s
    sp8s Member ✭✭
    Hi Arnold and Mike N0YPD
    Thanks for both answers and hints. Looks like I know what to do now ;D Cheers and 73!
    Stan SP8S
    Yes. The radio supports 2 clients from any source and any mix. Front panel, LAN, MAC, iPad regardless if they are a local or SmartLink connection.
    You can mix and match as required.
