Periodic network issues
I am curious if anyone is experiencing the same issues I am. I have a 6600m connected to an eight port gigabit ethernet switch (Netgear 308) to which my PC is also connected. Both devices are showing 1G negotiation. My network quality should be perfect, yet it's far from it at least according to SSDR. Sometimes I see the quality go red and the TX action on the radio is very delayed from when WSJTX initiates it. I've seen 6000ms. I've seen SmartSDR lose connection to the radio. I've also experienced significant latency with PTT on the front panel Maestro using my Heil trigger. I do not see this latency when SmartSDR is not running. I'm pretty sure that the network latency is somehow the cause of all of this.
I am running SmartSDR 4.1.5. I have done multiple factory reset procedures.
I have also put chokes on the network cables and switched them all out.
I thought maybe I was running through smart link and that might be the cause of the latency. I disabled it and am still getting the issues locally.
[Typo correction] I have seen these kinds of issues in the past. I have a 6600M with various switches in the path.
In my case, it was a defective switch causing the problems. I have also had the same issues with a bad ethernet cable. I would try removing things one at a time to see what cures the problem. First try direct connect, with either self-assigned or statically assigned IP addresses to the PC and radio - just a single known good ethernet cable.
I have swapped out the cable and swapped out the switch. I see zero network errors before and after these changes, but I still see a 2+second delay on WSJTX transmitting and when SSDR keys up
OutboundDiscardedPackets : 0
OutboundPacketErrors : 0
RdmaStatistics : MSFT_NetAdapter_RdmaStatistics
ReceivedBroadcastBytes : 537884
ReceivedBroadcastPackets : 1250
ReceivedBytes : 134973041
ReceivedDiscardedPackets : 0
ReceivedMulticastBytes : 780745
ReceivedMulticastPackets : 1643
ReceivedPacketErrors : 0
ReceivedUnicastBytes : 131961308
ReceivedUnicastPackets : 420383
RscStatistics : MSFT_NetAdapter_RscStatistics
SentBroadcastBytes : 6667
SentBroadcastPackets : 126
SentBytes : 231229407
SentMulticastBytes : 22338
SentMulticastPackets : 123
SentUnicastBytes : 229897726
SentUnicastPackets : 314520
SupportedStatistics : 41635830 -
I've noticed that my SSR network quality is all green bars until I transmit and then it goes red.
I have done yet another factory reset and now everything seems normal. I suspect something gets corrupted or something within the radio and it behaves oddly until fully reset again. Why it keeps happening is the real mystery.
I've had trouble (some years back) where my 6500 would not work reliably with Maestro at 1 gb/s. Always a nonzero error rate. This was "cured" by downgrading to 100 mb/s. Something to try.
Try using a 100 mb/s switch to force lower bit rate. (Gb electronics gets you rfi vulnerability with minimal performance benefit IMO.)
73 Martin AA6E
Thanks Martin. I'll have to give that a try. Unfortunately I'm using unmanaged switches and I don't see configurable parameters in the front panel of the 6600M to for its side to negotiate 100m.
So I've invested in a managed switch and set the 6600M's port to 100/Full. I've also purchased CAT 8 shielded patch cabled for every device. While I'm not seeing the operational impacts (delayed or no PTT), I do see the network quality (according to SSDR) varying wildly. Further, I'm having difficulty understanding the criteria used to determine the quality of the network. It almost seems arbitrary. Latency is low, packet loss seems to be a single event at SSDR startup, and the max latency hasn't changed.
Does anyone know how this diagnostic works?
Thanks and 73,
Mike N0MDH
I had similar issues with our club station setup .
Here the cure was to add a second small switch , 8 port gig , before the netgear 1 gbit 16port unmanaged. Since id did that , no issues. i plan to replace both with a managed switch . So currently the 8 port is connected to the Wireless bridge ( ubiquiti ) on the incoming side as well as to the flex and the netgear on the local side. Apart form the Flex ( 6k4) the network was PERFECT in all usage and several analysis progs testing UDP performance .
Nothing that was otherwise recommended to change helped even a bit. I remember it did work long time until mid 25 , since one update in earlyx septmeber 3.9 something all went bananas even downgrading did not stop that habit.
Harry
That's interesting Harry. I got the managed TP-Link switch Mike VA3MW has. I turned all the ports down to 100MF. Still dropping the connection. Why would putting an 8 port gig switch in front of the Netgear switch do anything? Regardless, I'm willing to try anything. Can you tell me the specific brand and model of 8 port switch you got? Is it managed? Did you turn it down to 100 Mb/s? Thanks.
Paul
N0GN
Here's another peculiar thing. It's pretty reproducible that when I spin the Maestro VFO at a good speed the Maestro disconnects. WTH?? I've tried hardwired connections to the Maestro, different ISP's. High quality patch cables.
I've tried the following and I still have unexplainable network quality issues (according to SSDR)
- Swapped all cables out for CAT8 S/FTP patch cables.
- Tried three different switches: 2 unmanaged, 1 managed (on this switch I tried steps 3 & 4)
- set the port to the 6600M to 100Mb
- set my PC port to 100Mb
- tried both with the radio registered to Smartlink and with it unregistered
- Tried with the 6600M Maestro not connected to the radio
I see no packet loss to speak of other than from right when SSDR starts up. I also see max latency at unexplainable levels of thousands of milliseconds. I continue to see periodic Poor and Fair quality reports from SSDR. 😣
Hi Mike, have you tried what Ted suggested (plug computer directly into radio)?
My guess is that RF is getting into the network.
In my own RFI case, I discovered that RF was getting into the switch via the Ethernet cables (including those that are unrelated to radio use). I also found problems with RF getting into the computer via USB cables.
To solve both of these I used lots of mix 31 ferrites. In stubborn cases, I had to wrap several turns of a cable around a mix 31 toroid. Most of it was solved by simple snap-on ferrite beads.
I do have ferrites on most everything, but I'll check again. Thank you. I would also think that the shielded CAT8 cables would act to filter RFI as they were designed to do. The one thing that makes me think it's not RFI is that this happens in the absence of transmission from the radio. I can watch it go from Excellent, all green bars, to fair (yellow), or poor (red) without me transmitting.
73,Mike N0MDH
Hi Mike, if it happens while not transmitting, then it is likely a network issue. You need to plug your computer directly into the radio. No switches, no routers. If the issue persists, try a different cable. If that doesn't help, try a different computer. The objective is to discover which component (switch, router, computer NIC, radio NIC, cable) is the culprit.
- 379 Community Topics
- 631 The Flea Market
- 120 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
