Configuration of WSJT-X for Flex6000/8000 Radios
Ken Wells
Ken Wells Community Manager admin
edited June 2025 in Third-Party Software
The Tutorial Document for Simple configuration of WSJT-X and JTDX has been updated:
Configuring WSJT-X for the Flex-6000 Series – FlexRadio
  • Mr Radio
    Mr Radio Member ✭✭✭
    As always, a great tutorial.
    TNX OM Ken
  • Hi, I changed from WIN10 to a WIN11 PC and now am a bit confused about the audio (DAX) settings in Windows for WJST-X to get if working with 6400. Any hints what I should change in audio settings from default values if any? Especially the Volume mixer Apps part is a bit confusing as it is something different vs WIN10.
  • David Decoons, wo2x
    The Windows volume level mixer settings should remain at default for DAX virtual devices.
    Set DAX TX level to 48 which should put TX and power slider in WSJT-X at max. TX level should be right at zero.
    Set the DAX RX audio to around 34. This should give a receive level in WSJT-X about 50 when no signals are present.
    73 Dave wo2x
  • OK thanks. Yes I had those DAX TX and RX levels configured roughly as you propose, only wondering about audio settings on Windows side. But ok those are fine with default settings.
    73 Pekka, OH2TA
  • Jim Davis
    Jim Davis Member
    Dear Ken,
    Thanks for the intuitive explanation that you had presented about getting my 6600m to actually WORK with WSJT-X! BRILLIANT JOB!!! IT WORKED!!!
    Jim-NN6EE
    Concord, CA
    Ham since 1962 & counting!
  • david ingebright
    david ingebright Member ✭✭
    Guys, I got this all set up, and it works good, except that the Win 10 list of DAX virtual audio selections is frightening. I am afraid to change anything now for fear of messing it all up. So, for example, I have this new FlexContro Knob. I want to tune around, listen to some other stuff, and try the USB headset. But to go in and change the virtual audio Windows selections is a major change to the setup. Is there an easier way to go from digital to analog operation without making big and possibly forgettable Windows audio settings?
    tx
    dave WB7ELY
  • Ken Wells
    It isn't necessary to make any changes in Windows Sound system at all..
    DAX allows you to select the DAX AUDIO RX and DAX Audio TX "devices" Directly from the WSJT-X Program as though they are separate Sound Card devices.
    To simplify the change between USB and FT8, simply configure two different Mic Profiles, one for SSB and the other for DIGU and associate them with the two different modes (By using them once)
    The radio will remember which Mic Profile to use for each MODE.
    This is covered in the document
  • W2PP
    W2PP Member ✭✭✭
    I’ve had this working for some time. Today when I returned to the room none of the three copies of WSJTX were seeing audio. I closed them and reopened them but no good. I shut everything down and restarted them all after a computer reboot. Slice A will not stay open it crashes after a few seconds. Slices B C D all function properly.
    DAX icon for A is blue. DAX 1correctly chosen for slice A.
    Don’t know what else to check here???
    Peter
  • W2PP
    W2PP Member ✭✭✭
    edited June 2025
    let me add that it’s pretty clear slice master is not connecting to slice A as it is for the other slices. Outside of slice master slice A works perfectly
  • Ippolito
    Ippolito Member ✭✭
    la configurazione non funziona con JTDX, strano….
  • NormanHeyen
    NormanHeyen Member
    I am a new Flex owner, an 8400, and trying to get this setup for WSJT-X. And working with DXLab, WSJT-X and JTAlert like I had running with my old Kenwood 570.
    In the DAX Control Panel, (running SmartSDR 3.9.18), the TX box for the TX Stream is not blue. It is sort of a Yellowish-green.
    Hovering the mouse over the box yields this:
    This channel is selected for transmit, the radio is trying to transmit, but the channel is disabled
    You must enable the channel by clicking on the channel number
    Where do I go to do that? Clicking on the TX button turns it grey and clicking on it again returns it to the same Yellowish-green.
    Please point me in the correct direction.
    Norman
    KC9NVN
  • johnn1jm
    johnn1jm Member ✭✭✭
    In SmartSDR, on the right or left control panel side under level, compression Proc Mon, there should be a button for DAX, Click on that and it should turn blue.
  • NormanHeyen
    NormanHeyen Member
    Thank you, Ken - that is exactly what I needed. I was able to successfully make a few FT8 contacts.
    Norman
  • I know this is an old topic but I am a new 8400M user +/-1 week, before I was using Ftdx101MP with DxLabs Commander and using the DxLabs commander as the radio choice.
    I just added for Commander the Flex by copying Internet Ip address with the serial number, next in audio RX & TX Flex radio. Nothing else to do at the exception to increase the Tx audio slider. I did not have to create any Port and DAX. It worked like before for both radios. Of course Commander must be running with DAX & CAT
  • Flexed
    Flexed Member ✭✭
    @Rejean Leveille there should be a flex radio in the selections
  • I am having CAT issues with my 6400 and 6500 remotes—please help - here is my story:
    I'm having the strangest problem with the garage 6400 remote radio. When I turn it on here in Maricopa and start the SmartSDR software on my laptop:
    1. I get a CAT error: "Cannot open TCP Port 5003."
    2. Serial Port COM4 shows as "Not Present."
    3. An "Error has occurred starting the Audio input" dialog box appears.
    4. A Windows OS dialog box appears: "An Error has occurred at 0x80070490" (this is the DAX reserved Audio TX virtual cable).
    5. I checked all the Windows audio settings, virtual cables, and Device Manager (including the COM4 port), and everything looks okay.
    6. The Windows sound settings have always been ambiguous and difficult for me to set up with this SmartSDR software. There are over twenty virtual cables displayed in the input (record) and output (play) sound card settings for third-party software.
    7. I am receiving an error that I cannot understand; it seems to be related to the Windows interface somehow.
    8. When I turn off the garage 6400 radio via WebRelay and turn on the mountain 6300 radio instead, I restart the SmartSDR software and that radio works normally. Both use the same software, ports, and virtual cables.
    9. This indicates something specific is happening only when the garage 6400 is running on this laptop!
    10. I can go to my desktop PC and the radio runs fine; the issue is isolated to the laptop.
    How can I fix this? I am considering reloading SmartSDR on the laptop. What do you think?
    • David, I would open a support ticket as there are a number of configuration issues here that need digging into. Off the top of my head it could be other applications using port 5003, duplicate Com 4 ports, etc.
