Smartlink Setup help
Follow up. I tried the setupo smart link button, disconencted radio….shows I am registered. The test button shows red.
I did the steps on the Maestro whiole on 4.01 version before, and it was the same red test. So I hope finding the instructions will solve it.
network settings are automatic. The Maestro was off.
Multiflex is enabled….
Paul
Did you follow Chapter 9 of the SmartSDR manual? It is well laid out there and no sense retyping it.
Thank you. and I just posted a discussion question on this. I was looking for a separate Smartlink/remote manual. (sorry!)
Mike, I think I passed by that manual many times because it is dated 2019. A lot of the YT videos are also 2017-2020, so IM worried about spending time on old material. Then finding the better one and learning it again.
Thanks again for the reply.
Ive spent hours now. changed settings on the router but smartlink will not test green. going to consult IT tech
All the videos and manuals are still current even though they are that old.
I need help. If everything ethernet I conenct to my router and switch work, this should work but it is not. I logged into the router/AP unit and looked at all the settings. Made sure everything was opened up. No restrictions. I will enter a help request.
I did go over all the manuals by now.
Ken Wells helped me. It was a matter of port forwarding. I just didnt understand needing that because the manuals said if things were set up in the router for UPnP the forwarding would not be needed. However the Smartlink was not happy with that so the forwarding was required. Case resolved.
- 390 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
