Is Static Routing on Unifi 4.4.6 feasible?
Hi!
I have two UDM Pro:s. One at radio and the other at my home. They are interconnected with Site Manager.
I try to use WireGuard to access my Flexradio at site. Setting up WGR is easy only "drawback" is that it creates another subnet 192.168.3.0/24 than where the radio is 192.168.1.0/24. The latency is 3 mS.
The trick is to allow a static route between the above subnets on the UDM at the radio site. But thid seem more or less impossible to do after several tries. Some posts on forums say the same.
However, I seem able to access my PC at radio site and ping the Flexradio. But getting ports 4993 with UDP packets thru seems impossible.
Anyone that have suceeded?
Or with ideas to circumvent this issue?
