Radio sport headset in mic profiles
I used my radio sport 1oth anniversary headset with my 6600 M. Can't remember what mic profile that works with the 8400M. M 207, 208, 350 20?
I suggest just create your own. Depending on what you do affects shape of the audio curve. For example, if primarily DX or chasing parks audio curve would cut below 400 and above 3000 or so to focus in the voice range for intelligibility. Always cut before boost.
Hi John. I run mine at 300-2850. what I was looking for is the right profile in the 8400M list of already in there profiles on the flex. I found that 20 works, but I think I used another one when I used this headset before???
John, it is better to build your own. Find any profile that gets it working and then start to tailor it to your voice (everyone is different). You can use the FDX feature of the radio to listen to yourself or even record a 2nd receiver and then play it back.
thanks Mike I found one and will work on it today.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
